my DVD burner has stopped working , the CD rom is okay, I did a factory re-set and now the burner does not show on the list of drives,I cannot re-install it as I do not have the installation disc, it was already installed in the computer, the burner is a Pioneer 106D and the computer is a MedionXL8080
Are you do firmware?
In most case when I do firmware upgrade with pioneer DVD, I can´t fix the problem.
Now you have trouble with chip on your DVD burner, the best solution is bay another, because you can´t try again firmware upgrade.
Only what you can do with dvd or cd rom is cleaning or change a laser, but you have diferent trouble.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
Thanks, I guess I will have to buy another
" - BOURBON72
My Mac computer won't recognize my new External GE20 Super Multi DVD Rewriter. We've connected it...
(More)
My Mac computer won't recognize my new External GE20 Super Multi DVD Rewriter. We've connected it properly to the computer and the light blinks but the computer doesn't seem to recognize it.
I did a hard drive wipe. At re-install I found that my backup was no good. After days of hair...
(More)
I did a hard drive wipe. At re-install I found that my backup was no good. After days of hair pulling I have all I need except for the driver for my burner. What information do you require to help me find this please.
hey there, i burned almost 2 gigs of photos to a dvd using the ''send to d: drive'' option and...
(More)
hey there, i burned almost 2 gigs of photos to a dvd using the ''send to d: drive'' option and everything seemed to burn fine. But when trying to insert the DVD into any other computer it reads it as a blank dvd. I've checked in several apps and it shows a session with the same size i mentioned but I have no way to access it. What can i do to access the info? these are 5 yeas worth of pictures and i desperately need them. Please help if you can..
Have a HP Touchsmart with TS-T633a CD/DVD burner. Hardware manager recognizes the drive but calls...
(More)
Have a HP Touchsmart with TS-T633a CD/DVD burner. Hardware manager recognizes the drive but calls out a code 39 saying drive maybe corrupt. Now what???
I have a slot feed version of this I don't know if its PIONEER DVD-ROM DVD-106/s or /a or what not...
(More)
I have a slot feed version of this I don't know if its PIONEER DVD-ROM DVD-106/s or /a or what not that dosn't get said on the propertys so not clue....it won't play dvd's cause I can't afford the decoder...that however is not my problem it will read and play everything else even OTHER DVD rom games like guildwars went in fine...but command and conquer 3 (pc dvd) I slide disc in cursor changes like its trying then spits the disc back out...getting frustrated please help...
