Question about IBM ThinkPad R50e Notebook
Failed on restart, had all lights, now no lights and won't do anything!
I uninstalled a program, hit restart and it never started back up. I had the battery in but no AC power at that time. I plugged in the AC and still nothing. I removed the battery, attempted to clean the contacts a bit and put battery back in and plugged in AC. It started to boot, got all the way to my background screen and started to display icons, went dead. I repeated the same process, the battery light flickered for a couple seconds, turned orange/red and then all the lights went out. AC doesn't do anything with or without the battery in. I can remove the battery, replace it, plug in the AC adapter and push the power button and the battery light will flicker once and then nothing, no lights at all! HELP!!!
Thanks in advance for your input!
Tim
    President:
  • 4,402 Answers
Sounds like your ac plug to the laptop might be loose you can try ans see if you can resolder it back. the other problem is your ac cord might be broken wiggle it around see if the light flickers.
Posted on Jan 03, 2008
AccuWeather keeps coming back after I uninstalled it
First, go to Programs & Features and see if Accuweather is there to uninstall again. If yes, uninstall it again, but do not restart immediately. Then, open Windows Explorer and, in the Program Files folder, delete any folder relating to Accuweather. Then on Desktop, go to Start/Search. Type in msconfig - click on it. A window will open, choose Startup. Uncheck anything related to Accuweather. Click Apply. Now, restart the computer. Good luck.
Dec 14, 2017 | Computers & Internet
I can not remove cyberlink webcam splitter from my system and it is interfering with my webcam
go to start menu/all programs/accessories/run and type regedit into the box and hit o.k.
Then go through the list and delete anything that has cyberlink in it's name...then close the window and restart the computer.
This will stop your computer from automatically starting any cyberlink programs that are hiding away.
Nov 16, 2012 | Computers & Internet
My pavilion dv7 17" won't allow me to install mcafee anti virus
Before you can do anything, uninstall norton antivirus, go to control panel and click on it, a list of items will come up, when norton shows select remove and wait for the program to uninstall, and restart the computer, go back in and remove norton live update and any other program pertaining to norton. If you have windows 7 go to my computer and "click" on top select uninstall, and follow the outline above. Now you should be able to install the program.
Mar 21, 2012 | HP Pavilion dv7-1137us Notebook
Missing tool bar when I uploaded to Explorer 7. I cant click on tools to get it back because I dont have a tool bar to acces
Try to uninstall IE7. Once it's removed, restart your computer then it will revert back to the older version IE6. After that you can opt to install IE7 again or much better a newer version like 8 or 9.
To uninstall IE7, kindly follow these steps:
  1. Close all programs.
  2. Click Start and then click Control Panel.
  3. Click Uninstall a Program under the Programs category
  4. In the Tasks pane, click View installed updates.
  5. In the list of installed updates, double-click Windows Internet Explorer 7. In the Uninstall an update dialog box, click Yes.
    Note If you are prompted for an administrator password or for confirmation, type the password, or click Continue.
  6. Follow the instructions to uninstall Internet Explorer 7.
  7. When the uninstall program is finished, restart your computer.
  8. After you restart your computer, open Internet Explorer. Click Help>About Internet Explorer and check if it's on version 6. If it is then proceed with upgrading to a higher version again.
    Hope this helps.
Nov 18, 2011 | Microsoft Internet Explorer 7
MediaSmart WebCam won't start up
Remove the webcam from the PC- program list . Uninstall the driver and shut down. Now restart and then plug back the webcam to be detected and installed. if not check the cam with another PC. If cam works then check the port or the OS in your PC.
May 14, 2011 | Computers & Internet
CAN'T FIND UNINSTALL FILE FOR SPY SWEEPER. Is causing conflicts with Trend Micro
Have you looked in the Spy Sweeper folder, most probably C:\Program Files\Webroot\Spy Sweeper and looked for the uninstaller - unins000.exe
You could always search for this file through Start>Search, select all files and folders and type "unins000.exe". It should find the file, this is the uninstaller, just double click.
You could also start in Safe Mode (restart computer and hit F8 when computer first starts) and delete the webroot folder C:\Program Files\Webroot\ . Do NOT try to delete the Program Files folder...
Good luck! Let me know if you need further help. I will check back tomorrow.
Feb 12, 2010 | Webroot Spy Sweeper (spysweeper) for PC
0xc0000005 application failed to initialized proplerly) (click on OK to terminate the application) how to uninstall google chrome. google chrome does not uninstall whenever i try to uninstall it.
this is a common windows error. if a certain application stops working like your google chrome. try to edit start up items, click on start, click run, on the run box type : msconfig. click ok. on the start up tab, click on disable all on the bottom right, hit apply or ok. it will give you a prompt to exit with restart. this is for xp, if its vista more likely the same but after restarting the computer, no prompt for system configuration utility will pop up. to unisntall the google chrom, if its xp go to add remove programs and click remvoe, if you have vista, go to program and features and uninstall it from there, if no go. use the microsoft installer clean up utility. http://support.microsoft.com/kb/290301 just download and install it then look for it under programs and it will gie you all the programs installed on your computer, you can look for google chrome and uninstall it. that should work.
Sep 11, 2009 | Dell Inspiron 530 -Intel® Pentium®...
Keyboard lockes up when attempting to log in with password. wont type anythin. also lockes mouse when i touch any key.will not work with an external keyboard via usb. cant get in
Hi there.
Restart the PC and boot into safe mode by pressing F8 just after the post/splash screen, this will take you into a sub menu with a few advanced choices, choose safe mode and hit enter.
The PC will start up with minimal drivers, if it lets you use the keyboard perform a system restore and take the PC back to a date before you uninstalled all the programs.
When system restore is complete it will restart and boot up normally, hopefully now you will have the keyboard back and you can proceed to uninstall spyware doctor etc.
Don't uninstall anything that you are unsure about, if you have to post back on here and ask if uninstalling a program will affect the system or hardware.
If the keyboard still does not work please post back for more advice.
Good luck and thanks for using FixYa!!
May 19, 2009 | HP Pavilion DV6120us (882780876934) PC...
Action failed for file avgtdix.sys: starting service....
There is a known issue between AVG 8 and Anniversary Edition of Ad-Aware which gives exactly this error, so if you perhaps just got that ad-aware, uninstall it too before trying to reinstall AVG.
Then run the uninstall/cleanup util for Avast because the Windows Add/Remove isn't good for uninstalling antivirus programs. Then try reinstalling it again. If you downloaded the installation package, then it provides the uninstall option. Disable Ad-Aware's Adwatch first! Run the AVG installer. Choose the uninstall option and follow the wizard. When you get to the part to remove user settings, select it. Restart your computer then... Now reinstall AVG using the setup file you got and update it.
Restart Windows twice before you re-enable anything disabled earlier.
Should this not work and you get the same error, that means the original errornous installation is still not out of your system. Download the AVG remover from here:
http://www.avg.com/download-tools
Remove your AVG and reboot to make sure it is not there any more, and try installing again.
Let me know if the solution worked and if yes please rate me:)
Feb 01, 2009 | Computers & Internet
Problem
I understand that when you try to increase the volume the programs freezes.
To isolate the issue please uninstall HP Quick Touch Software.
Here are the steps to uninstall HP Quick Touch Software.
Click start and select Control Panel
Then select Programs
Then select Programs and Features.
This will show list of programs
There select HP Quick Touch Software and click on uninstall/Remove.
Then restart the Notebook . This should resolve the issue.
Thanks.
Aug 21, 2008 | HP Pavilion dv9000z Notebook
IBM ThinkPad R50e Notebook Logo
180 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
