Toshiba TDP-S20U Multimedia Projector
Toshiba dlp s20 projector
shared by 2 users
posted by motionmaster on Jan 03, 2008
hi my projector was purchased in 2004 and has clocked over 5000 hours with one bulb, i decided to replace the bulb as the picture was deteriarating the projector ran on standard power for the last 2000 hours of its life and the unit started to not power up when switched on, it tended to whistle and the fan sounded like it was blowing very quickly, i replaced the bulb this morning and the picture has improved perfectly, although i am satisfied the unit still refuses to activate when i switch it on at first, after 2-3 attempts it runs but still whistles at first, originaly it started first time every time. have you any idea why this is happening or what can i do to ammend the problem.
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Posted by Who Shot JR on Jan 07, 2008
I have a similar problem, and it seems to be getting worse. I'm not sure how old it is, but the S20 was in my house when i bought it a year ago. When i try and turn it on, it sounds like it's trying to power up then stops. It makes this whistling/humming sound off and on again and then eventually gets going. But, sometimes it gives a picture, others i get a snowy screen. The time log for the lamp shows only 500 hours of use. The lamp should be OK. Right?
Solution #1
posted on Oct 30, 2008
Not Rated (0)
lauco11
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I have the same problem. The whistle is the color wheel turn on and off. It is the power control issue.
The power supply try to send cntro power to the wheel and the lamp.
More likely is the capacitor leaking is the power supply.
Contact dealer for replacement part.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on toshiba dlp s20 projector:
I don't want to Accept this solution
Solution #2
posted on Feb 11, 2008
Not Rated (0)
NinHowFritz
Rating: 0%, 0 votes
There is another problem that I encountered with this projector. I took the lamp out to clean and see how it worked, then when I put it back in, it must not have been centered right. Shortly after, the projector made a startling loud buzzing sound. It turns out that if the lamp is allowed to shine into the projector off center for too long, the beam hits a small piece of sheet metal just past the color wheel, causing the metal to warp. The buzzing sound is the metal rubbing against the spinning color wheel.
Thank You!
Solution #3
posted on Jan 22, 2008
Not Rated (0)
Wild99HD
Rating: 85%, 1 votes
both of you have fan and cooling issues. The fans are dirty and that is why they whistle. Try dust off or highly compressed air and blow them out really good and long. This should help. BTW the life expectancy of the projectors are avg. 5000-6000 hours total lifetime.
Thank You!
Can you Help with these Multimedia Projectors problems?
I bought it in fall 06. Used it for 635 hrs. Projector...
Quick Question oh mighty one, 2810 Compaq projector,...
hi, whenever i turn on my projector, it stays on for maybe...
dear sir / madam My projector Toshiba type TDPS20, have a...
Projects grey until you turn it off and on multiple times...
Loading problems.
Repair Service
Find Multimedia Pro. Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
