Question about Procom ML300HGA Heater
Altitude Hello I live at an Altitude of 4800 feet,  Will this heater work at that altitude?  What would be the concerns? Thanks Lynn Vance
    Problem Solver:
  • 18 Answers
Carbon monoxide,possible death.leave window open.
Posted on Jan 04, 2008
Does the altitude of 4000 feet has affect on someone with low blood pressure?
I am not a doctor but I can tell you that at 4000 feet there is about 87% of the oxygen compared to sea level. High altitude is usually defined as 5000-11,000 feet. High altitude actually increases the body's blood pressure.
Dec 10, 2016 | Health & Beauty
Can I convert the Hayward h100idp to work in higher 4500 altitude? Itsays it only works for up to 2000 feet.
check with hayward before you do anything make sure you have adequate gas pressure
Feb 21, 2014 | Hayward Pool & Spa
HAYWARD H100IDPI altitude change
you should have specified high altitude contact manufacturer
Nov 25, 2013 | Hayward 100,000 BTU Pool Heater H100ID1 -...
Hi i have installed a lowrance m52 s/gps in my boat i have turned it on while boat still on trailer and the unit is reading 5.6 ft deep, is this what it should say?
GPS uses satellites to determine position and altitude. Depending on where you are, above or below sea level, it may say you are flying in the air or a few hundred feet below the water. YOU have to determine what your mean altitude is by knowing what the local altitude is above or below sea level. If you were in Denver, Colorado, it would tell you that the boat was about 5,341 feet up in the air. In Death valley you would be below the water because it is below sea level, -272 feet.
Aug 25, 2012 | Lowrance Boating
I can do the same ride with the unit on different bikes and get a variation in total ascent by as much as 200 feet
When starting your device, it acquires sttaelites progressively, then the altitude accuracy is not good at the beginning, so starting altitude and final altitude are not identical if you ride a loop.
Other possible cause is that the cumulation of small errors makes cumulative altitude to vary.
Garmin connect offers a feature that corrects the altitude by smoothing the waypoints, and also by using topology points.
Go to http://connect.garmin.com/
Then upload your data from your garmin device to the garmin connect database, and use the feature named "altitude correction" bottom left of the screen where your ride is detailed
Aug 27, 2010 | Garmin Edge 305 GPS Receiver
Installing high altitude kit on Cozy NG furnace
the orifice that comes with the unit has a starter hole only needs to be drilled out, in the instructions is a chart for altitude de-rating.
Oct 04, 2009 | Cozy Enclosed Front Console Heater 20,000...
High Altitude Electric Heaters
I have never heard of altitude effecting the electric. Watts amps and volts are different than burning a gas, like propane. The high altitude has less oxygen thus requiring the combustion to be effected. If your wires are over heating when you use maximum wattage (amps) you need to install larger wire with the correct size breaker. Look up ohms law. Its a basic electrical formula and will help you get this right.
Dec 26, 2007 | Dayton Electric Heater
Incorrect altitude changes
Here is the link to the user manual for this watch if you need it; http://www.lacrossetechnology.com/k2100/manual.pdf page 12 gives you all the contact details for lacrosse. I couldnt find the info online to be sure, but some of these watches do have a separate pressure sensor for altitude and barometric pressure, and sometimes the path to one could get blocked or it could become faulty. I would contact la crosse and find a dealer to get the watch serviced, you could probably do it yourself but you need to get replacement seals from them anyway (these are important). ask them to check if the sensor is clogged, it happens sometimes. Hope this helps :)
Jun 18, 2006 | La Crosse K2-100 Wrist Watch
Procom ML300HGA Heater Logo
Top Procom Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
