Adjust the legs on the bottom of the washer so that all legs are touching. requires a 1/2 or 9/16 inch wrench to loosen the lock nut then adjust the leg to where they touch the floor evenly plus a 1/8 turn then try it. If it still bounces around you may have a mount that has come loose, if so post here and I will Post what to do next.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Splendide 2100 Front Load
Splendide 2100 Front Load All-in-One Washer / Dryer
Hello, I have a Bendix WDS-1043 washer/dryer combo and the drum won't wpin. Also, the timer knob...
(More)
Hello, I have a Bendix WDS-1043 washer/dryer combo and the drum won't wpin. Also, the timer knob doesn't seem to move either, or at least it didn't while I was standing there and watching it (it should move minute by minute as the cycle progresses right?). The washer fills with water and then stops, you can hear a low hum but the drum doesn't turn and the timer doesn't move. If I manually move the timer the pump will run and empty the washer, but then nothing else happens. This is the first I've used FixYa so I hope I posted this properly. Any and all assistance would be appreciated!
have a bendix wds 1043m washer. It will not spin.I disconnected belt to drum motor will not not...
(More)
have a bendix wds 1043m washer. It will not spin.I disconnected belt to drum motor will not not activate on spin cycle running free . Can you help
