Home | GE | (PSS26MSRSS) Side by Side Refrigerator | Both the freezer and ref...
GE Side by Side Refrigerator
Problem for GE (PSS26MSRSS) Side by Side Refrigerator
Both the freezer and refrigerator will not stay
By fourrunr23 on Nov 02, 2009
Both the freezer and refrigerator will not stay cold enough, unit is about 5 yrs old. Both sides are warming up, it just won't stay cold enough on either side. I took everything out and let it defrost for 24 hours and everything went back to working for about 2 weeks then it started warming back up. Please help
Best Solution
posted on Nov 02, 2009
Very Helpful)
salde386
Rank: Guru
Rating: 93%, 41 votes
you must have a defrost problem,open the freezer door,do you hear the fan blowing,if not change evap fan motor,remove second from bottom bin and touch the back wall if you feel ice or snow there you have a defrost problem check the t-stat and heater,not sure but if you read the tech sheet i think you can click the light switches to put into defrost,also if plugs are on t-stat,unplug them and bypass the t-stat by pluging the wire to the heater,if heater comes on then you have bad t-stat if not read out heater with meter,also ge has been having alot of problems with the mother board ,if you defrosted it and it happened again in a 2 week period i dout it's the board
Comments:
Nov 03, 2009
- i want to tell you that you should call in tech to check out your machine,on the newer ge models there are thermistors,it could be the main board but you also have to change the thermistor that is next to the evap coil
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Somewhat Helpful)
rolingking
Rank: Wiz
Rating: 84%, 197 votes
Since this is a recurring problem, let it be check by
refrigeration technician who have the tools for checking
it up, such as compound gauge gas analyzer for the
refrigerant, pinching tools, brazing tools. Actual check up of the refrigerant level, load test (ampere drawn)
But for the mean time, you may have it defrosted, and clean up the condenser.
Comments:
Nov 02, 2009
- Since this is a recurring problem, let it be check by
Was this helpful?
Yes
No
Popular Solutions for GE Side by Side Refrigerator
Questions and Unsolved Problems for GE Side by Side Refrigerator
Do you recommend GE (PSS26MSRSS) Side by Side Refrigerator?
Answer
Answer
water is not dispensed at the door when switch is activated
Answer
Ice is forming on the bottom of the freezer and comes back after melting it off.
Answer
water pump is not working water flow is very slow
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE Side by Side Refrigerator:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 881
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(816) 471-5334
* Please Contact us for More Information
At Your Service Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
