Question about HP OmniBook XE3 Notebook
Hi :) plese help
on boot, my notebook hp omnibook xe3 display this message:
Resource Conflict - PCI on Motherboard
Bus:00, Device:08, Function:00
Bus:00, Device:08, Function:01
Resource Conflict - Network Controller on Motherboard
Bus:00, Device:10, Function:00
sory for my bad english :) p.s.myself flash bios with 1.61. to 1.63 ver.and again display SOME ERrOR
mesaga as ago (before) .
Wheather have mind in ordar to fix mine problem with notebook.....:)
---SASHA from croatia please reply to
  • 2 more comments
  • sashko Jan 03, 2008
    when REMOVE ALL ,sd memory 256,modem,flopy drive,dwd rom, display this only one message ERROR
    Bus:00, Device:08, Function:01.....
    my fault ,with memory 256 display ERROR
    past (off) memory 256mb ,beep speaker 3x slow with pause :)
    beep...beep....beep....long pause.....beep....beep....beep
    sory poorly speak english .....:)
  • sashko Jan 14, 2008
    Problem is equal as and before,after remove minipci module(modem/lan...) display on one mesage Resource Conflict - PCI on Motherboard
    Bus:00, Device:08, Function:01......WHAT is also malfunktion :(
  • Anonymous Feb 28, 2008
    I have exactly the same problem posted by sashko; removing the modem/lan minipci module (as suggested) I get "just" one conflit:
  • 4,402 Answers
Remove all external devices and try again does it beep at all?
Posted on Jan 03, 2008
  • Cary Farah
    Cary Farah Jan 04, 2008
    the modem/lan minipci module is faulty. from there
    you have that error messages and also from here you can't access your
    lan and again (guess) you don't have sound. very strange but true.
    what you have to do is to remove the lan/modem minipci card (baterry to the right) and everything you be OK.
    and if I remember correct the spare part number is: F2300-60914.
    if that doesnt work try this:
    entered the bios setup utility and changed the settings for the parallel port to simple port ( no ECP no Bi-directional)
    this way it saves resources for the mini pci card that reports the conflict
Getting the following error on boot up right after the ibm splash screen: ERROR Resource conflict - PCI Serial Bus Controller in slot 7 Bus:15, Device::00, Function:01
If it is not making it to Windows at all...Generally occurs when two devices are using the same IRQ or memory allocation. This can sometimes be set in BIOS depending on the manufacturer etc. I would start by going in BIOS and restoring the default settings. There should be a menu item in BIOS usually something like "Restore Default".
If it is making it to windows then you probably just have a missing or corrupt driver. Generally this would fall under a chipset driver which can be downloaded for free from hp's site. You can also download and run Everest or SIW to properly id the device in question.
Comment back with for findings results or for more assistance.
Aug 24, 2011 | HP OmniBook XE3 Notebook
Whenever I turn on my laptop I get the Error: Resource Conflict-PCI Network Controller on Motherboard Bus:08, Device:00, Function:00 Bus:08, Device:01, Function:00
You have a device that is attempting to use the same IRQ as another device that has loaded before it. Go into the device manager and look for a device that has a yellow triangle with an exclamation mark inside. You may find a couple.... Open the device properties and see if you get some indication of which other device it is having conflicts with. Then it is a matter of uninstalling one of the devices and rebooting, letting Windows re-detect the device and install it again...hopefully with the correct IRQ assignment this time.
Feb 17, 2010 | HP OmniBook XE3 Notebook
My laptop wil not boot. Not even in safemode . It has wndows xp that i had recently put on there.. its been doing this for a min but it would come on after a few tries.. This is exactly what happens when i...
Hello Karen
Try removing and resetting your memory modules.
Blow some air in the slots to remove any dirt trapped in there.
They are locate don the back of your laptop.
The instructions are in the manual under how to change or upgrade memory modules.
Please don;t forget to rate this answer if it helps
Jul 22, 2009 | Acer Aspire 5100 Notebook
Hp omnibook xe3 password removal
Call HP, prove you purchased the omnibook and they'll help you.
Jun 12, 2009 | HP OmniBook XE3 Notebook
I forgat
hi you can open it and take out a battery for 5 min
Oct 21, 2008 | HP OmniBook XE3 Notebook
Resource Conflict - PCI on Motherboard Bus:0A, Device:09, Function:00 = CARDREADER PROBLEM
I did try all that, and it didnt work, on a 5050 acer built on a 3100 gabinet.
I think that the problem is that the cardreader chip is not well glued to the motherboard, that's why it gives you that error. If you try pressing certain points of the computer while booting, it miraculously stops giving that conflict error.
We should be payed back by Acer, as this is an project issue =P
Jul 19, 2008 | Toshiba Satellite A105 Notebook
Post Erros
well...the error codes are usually from MSoft, if on boot up...most are operating system related..
Mar 23, 2008 | HP OmniBook XE3 Notebook
Re: Hi :) plese help
try to refer this problem to your manufacturer/ store owner of your laptop because most probably its either your memory(RAM) or your video card needs to be may have loose their connections.
because in the desktop PC's, these are the common problems especially upon booting up your computer.
Jan 16, 2008 | HP OmniBook XE3 Notebook
OmniBook XE3 Boot Problems
did you replace the ram?
If so take it out and see if it starts up.
Nov 28, 2007 | HP OmniBook XE3 Notebook
HP OmniBook XE3 Notebook Logo
378 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
