How do I reset the clock for the one hour time switch? This was the first DST switch since broadcasting went digital. The loss of the TV guide is no big deal but cannot I cannot change the clock. The "Manual Clock Change" option is greyed out. I could try lying about my zip code to see if it will adjust but I ought to be able to set the clock manually.
The Panasonic DMR-EH50 can be reset like it was brand new. I assume the DMR-EH55 can be also. The up and down channel buttons are located on the front of the unit behind the small door in the center. With the unit on press and hold these two buttons for atleast 10 seconds. This will restore the unit like it was new and you will need to go thru set up procedure. The above action will put the unit in the off position. When you turn it on it will guide you thru the set up procedure. Once this is complete you can press the setup button and manually set the clock, however, the unit will need to be shut down for 24 hours to allow the tv stations line-up to be restored.
My DVD recorder will not record to disk. The disk drive doesn't seem to recognize that there is a...
(More)
My DVD recorder will not record to disk. The disk drive doesn't seem to recognize that there is a disk in the drive, because it gives the same error message for both blank and pre-recorded disks. It says that the disk cannot be played because because it is either damaged, finalized, etc. I have tried many different disks as well as disks from different manufacturers to see if that was the problem. This whole problem started when I was dubbing to a disk and the recording was interrupted. I was out of the room at the time so I don't know what happened to prevent the program from being copied. The disk that was being recorded to won't load either in the recorder or in a DVD player that I have so I can't tell how much was actually recorded on it. My manual doesn't seem to have anything to say about this problem. I have tried resetting the recorder. That hasn't worked either. Do you have any suggestions as to how I can fix this?
Thanks,
Ken
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
