1. Clogged drain line or water pump Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
3. Drain Filter Check the drain filter for clogs as well. This filter can become clogged overtime, preventing the free flow to exit the drain tube. It is located inside the unit, mounted on the pump housing.
**The most common issue will be an obstructed hose or, line
NOTE-If the hoses filter,and pump check out ok, this will confirm that there is a serious within the actual control sector(Timer module or control board). It should be replaced i this case.
Was this helpful?
Yes
No
Popular Solutions for Whirlpool Duet GHW9150P Front
I have the same problem, however I cannot find my manual. Can someone please walk me through the...
(More)
I have the same problem, however I cannot find my manual. Can someone please walk me through the steps I need to try before paying someone to come out and fix.
