It seems like you horizontal board and circuit may not be firing up. But, first you should try a different outlet and power strip and see if that resolves the problem. Back in my day the reset button always seem to do the trick , not any more and you may have tried that already.
Are you getting any light blinking? If so, can you tell me if it is blinking slow, fast, or what?
Can you see if it will blink back an error code? It really isn't to hard to do. Press the input and the menu at the same time, and hold them down for about 5 seconds. I'm sure it should have an input button but, you might have to use the power button instead. However, count the blinks and wait for a pause and then count the blinks again. This TV should give a two digit error code. If successful post a comment on what you were able to get.
The horizontal output has a few diodes that may have went bad. Or the DM could have troubles too. Let's pray a surge strip is all that is needed. I'll have to hold up until you respond for now just to see where it will lead us. I'll keep checking to see if you posted a comment so, that we can continue to troubleshoot this problem for you. Hopefully we can solve it fairly quickly.
