Question about Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
Mitsubishi WD-62725 62 in PC input Noise issue
Started noticing noise on my PC input. Swapped VGA cables and laptops, no change. All other inputs display fine.
  • nicolie73 Jan 25, 2008
    I recently noticed it is not limited to just the PC input. The noise now appears on all the menu option windows with no video input selected. I tried plugging in power to different circuits throughout the house without any change.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 175 Answers
Well it seems to be a problem with the Cable or connecter.
double check the pins if not any1 is broken.
Posted on Jan 25, 2008
  • Waqar Khurshid
    Waqar Khurshid Jan 27, 2008
    may be the seal broke and air got into it.
  • Waqar Khurshid
    may be the seal broke and dirt got into it.
  • 4,102 Answers
Hi happy new year.
If you are sure the leads are ok and you sure the problem is with the telly itself then the problem is likely to be a solder one.
Where you plug the lead in thse sometimes work lose causing a bad connection.
If this is the case then you will need to remove casing and resolder the input terminals that go onto the board itself.
You could even replace it with new one to be sure its not the connector itself causing the problem.
The other problem that can cause interference with this type of telly is what i had and that was i had several units connected to my telly and my ps3 sound was making noise but i found out if i disconected other items plugged into my telly then the sound would be fine i was told that it was to do with using cheap leads to connect the equipment with so try this first and see if the sound is better as taking the telly apart is something as a last resort.
Also if you are unsure what you are doing then its best to take to repair shop as you could destroy the telly.
If it is only solder problem this should be repaired for next to nothing.
If this is also not the problem you will then need to look at all the resistors around the input port and also on the amp part of the tell where the speakers on the telly are connected to the board.
You will need a good magnifying glass to check all resistors but remember these telly carry really high voltage that will kill and the telly is still live upto 24 hours after it has been switched off at mains.
So if you are unsure please leave to pro as you could destroy the telly and even yourself.
If you are doing it yourself make sure you earth yourself out by touchin something metal like radiator that goes to earth as the static can destroy chips on the board.
Let me know how you get on ok
Posted on Jan 03, 2008
    Guru:
  • 1,894 Answers
1. Unit powers on and works properly for a while then shuts off with a red lamp LED (lamp error). Suspect bad lamp part # 915P020010 2. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977020 3. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977020 4. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977020 5. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977020 6. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if low or missing check C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the Power PCB part # 934C148001 From the noise you described it could also be that the color wheel is failing. Fans and the color wheel can cause shutdown. And if any of this sounds too complicated it's time to bite the bullet and take it into the shop. Find a reputable shop and one that will give you a written estimate before proceeding. If you ned help locating one try the NESDA locator: http://www.nesda.com/locator/state_search.php Hope this helps
  • 1 more comment
  • dewan nafees ahmed Jan 03, 2008
    heck mitsubishi updated service flash. remove the thermal sensor and
    put a jumper across the connctor. if this does not fix it then replace
    the power board.
  • dewan nafees ahmed Jan 09, 2008
    check mitsubishi updated service flash. remove the thermal sensor and
    the power board.
  • dewan nafees ahmed Jan 25, 2008
    you dint mention if u have tried all solutions mentioned here or not?
  • 2,427 Answers
There could be a problem with the connector it self or try your default settings here is a usefullink that could help
http://boardreader.com/t/Rear_Projection_Units_16082/Official_Mitsubishi_WD_XX833_Owners_Thre_899744.html
and this one
www.hdtvsolutions.com/pdf/MIT_WD-52525_WD-62525_WD-52725_WD-62725_Manual.pdf
you can try servicing or changing the connector your self
THIS IS THE HTML LINK
http://72.14.205.104/search?q=cache:Z1FFmuoMqjAJ:www.hdtvsolutions.com/pdf/MIT_WD-52525_WD-62525_WD-52725_WD-62725_Manual.pdf+Mitsubishi+WD-62725+pc+input+noise&hl=en&ct=clnk&cd=18&gl=tt
you can download your service manual for the Mitsubishi WD-62725
and attempt repairs your self or take it into a profession.
REGARDS
Trying to connect Laptop VGA to TV Component (RGBHV) INPUT
Computer VGA to TV AV RCA S-Video Composite Converter, Costech HD 1080P HDTV Video Cable Converter Adapter Plug and Play for HDTVS, Monitors, Display, Laptop, Desktop, PC
Go to Amazon and for $10 solve the problem
Feb 04, 2018 | Mitsubishi Televison & Video
I have a Mitsubishi projector model WD 73640 can I use LGSoundbar? Back of TV has a DVI/PC Audio Input
The PC/DVI is an input to the TV You need an aux out or monitor out. If you try using the PC audio input you won't hear anything. It's only for computer or laptop sound cards.If the TV has an optical out and the sound bar has an optical input then you can connect the two that way. You;ll need an optical cable for that.
Oct 22, 2016 | Mitsubishi WD-73640
PC DVI-D to Mitsubshi DVI-I no signal
have you set the dvi out to 720i as any higher the tv will not read it as a signal. you will need to verify it in properties windows will set it at 1080i. you need to change it.
Mar 08, 2014 | Mitsubishi Televison & Video
How do get my k100 to work on my tv
1. Connect your laptop with your TV using a cable (HDMI or VGA),
2. Turn on your TV and change the input in your TV (PC input/VGA/HDMI. Please notice that some TV have more than one HDMI input port, so you need to check it which port is connected to your computer),
3. Turn on your laptop and change the output in your laptop (cycle it: laptop only, external display only, both) using Fn key and the screen cycle F key (please see the orange icon on the F keys).
Mar 01, 2014 | Advent Computers & Internet
How to connect my desktop computer to my mitsubishi hdtv?
If it has a PC input, no problem, just use a VGA cable. If not, don't waste your money on adapters to convert from PC to HDMI or Component. Picture is lousy and poorly focused. If your TV has a DVI input, That will work. frequency will match up. Hope this helps
Jan 09, 2011 | Mitsubishi WD-57733 57" HDTV
I get lines running across my television (wd62525), especially noticeable when screen goes black. video noise? and it moves horizontally across the screen.
Sounds like interference or signal contamination. Does it occur on OTHER inputs? If not..then the input signal is corrupt, weak, has interference, wrong cable, or othewise defective.
Jun 09, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Connect Macbook Pro to Component input
you should be able to use an SVGA to component rca connector on any component input - i have a wd-65513, and thats how I have my pc hooked up to it. I could also never get a clear picture using the SVGA plug on the back of the set.
Jan 12, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Video noise
noise on all inputs ?
do you have these connected via RCA or svideo connections.
If you can use the digital inputs hdmi
Here are some other ideas
inplug all your inputs and see if you still have the noise bars
if you do try unplugging any device in the same circuit
do them one at a time to see if you can find the unit causing the noise
be sure and have all of your power and input cables away from each other where they do crosss try to get the junctions as close to 90 degrees as possible
Sep 29, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsu WD 52525 confusion
to change the channels on the vga side you need a tuner that has separate component inputs and you would change the channel on that
Jan 28, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
83 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
