Transformer I have a Viewsonic Monitor VE170b - serial #AOA020600968, model #VLCDS22034-16. The transformer - Model:HASU05F apparently went bad during a bad storm - had three consecutive power outages before I could get to the cpu and monitor to turn it off and this happened even tho I have a surge protector. the plug appears to be okay and does the wall socket. my monitor will not come on Help, Terrie
    Scholar:
  • 95 Answers
Several things have happened. 1st have you tried plugging the monitor in the wall and not in the surge protector. 2nd does your power button or LED light uo when you power it on? You have stated the transformer is bad due to lighting strike. Have you replaced the transformer? Your monitor should be coverd under the surge protector warranty. Please answer questions and we will go from there.
Posted on Jan 10, 2008
View Sonic Monitor Serial No. QQ2081640466 Model No. VS11826 please let me know warranty of this monitor
Hi u3salkar, What the warranty covers:ViewSonic warrants its products to be free from defects in material and workmanship during the warranty period. If a product proves to be defective in material or workmanship during the warranty period, ViewSonic will, at its sole option, repair or replace the product with a similar product. Replacement Product or parts may include remanufactured or refurbished parts or components. The replacement unit will be covered by the balance of the time remaining on the customer's original limited warranty. ViewSonic provides no warranty for the third-party software included with the product or installed by the customer. Check this link ....http://www.viewsonic.com/support/warranties/limited-warranty/
Hope it may helps:
Regards; VOTIT
Dec 03, 2010 | ViewSonic VA1716w Monitor
ViewSonic VE170b 17" LCD Monitor Faulty power
You need to check the fuses on the backlight inverter board, also the logic board may be damaged by the AC voltage.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Dec 02, 2010 | ViewSonic VE170b 17" LCD Monitor
MY MONITOR SCREEN WENT DARK AT WINDOWS STARTUP THOW POWER SUPPLY IS THERE PLZ HELP.............
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder jopints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Jun 07, 2010 | ViewSonic VA712B 17" Flat Panel LCD...
Mouse movement is not clearly visible & get more H'lin brightness
Have somebody take a look at the capacitors in the power supply first, look for caps that are leaking/bulging top, very common failure in LCD monitor.
Please see some failed bad caps album and failed VIEWSONIC monitors due to bad caps here:
Jun 01, 2010 | ViewSonic VA2226w 22" Widescreen LCD...
VG2230WM (Black, Gray) LCD Monitor: Will not power up, no LED power light...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 18, 2010 | ViewSonic VG2230WM LCD Monitor
Half way through pc posting screen goes blank Viewsonic VA1912W LCD Monitor
Common failures in this monitor is the 470uF caps in the inverter section (close to the inverter transformers), but you should replace all the caps in the 5vdc and the 12vdc as a whole set. See example of failed VIEWSONIC monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 26, 2010 | ViewSonic VA1912WB 19" WideScreen Monitor
View sonic va1703wb model no: vsa11534 serial no: qfcko70600651 is it warranty please tell me because my mointor was no display
Follow the following steps:
To obtain warranty service, email service.us@viewsonic.com.
To obtain warranty service, the following will be required :
The original dated sales receipt (include reseller name, address, phone #, product model, product serial number, and your name if applicable)
Your name
Your company name
Your shipping address (no P.O. Boxes accepted)
The serial number of the product
A description of the problem
Regards
Ashly
Feb 03, 2010 | ViewSonic VA1703wb Monitor
Computers & Internet Logo
100 people viewed this question
David Payne
David Payne
