Question about Philips HTS3450 System
Need device code for universal remote
Cannot find anywhere -
listed codes will work pieces of the remote, typically power.
Whoever runs philips customer support can drown in lava too. They're worthless
  • 476 Answers
There isn't a single code to work the entire system. Typically you will find a code to work the DVD functions, and a separate code to work the amplifier functions.
If you have a multi-device universal remote, you will need to set separate codes.
Posted on Feb 13, 2008
Lost the remote to my philips HTL2101A and it has no power button, so i can't use a programmable remote.
It should still be possible to use a universal remote to power on your TV.
Some universal remote instructions will say that the device has to be turned on in order to properly program the remote. This is not necessarily true, and you should still be able to use the universal remote to find a preset that will at least turn your TV on so you can then follow the instructions for the remote to find the exact preset that will work with every button on the remote.
First, look in the instruction booklet of the universal remote for the section of preset codes. It should be a huge list of 3-5 digit numbers with corresponding device names. There should be at least one or several for Philips devices. Find the code that matches your device.
Then, follow the instructions to program in that code. Should be something like: Hold down a certain button until the light on the remote blinks. Enter the code. Press another button to program the remote for that code. Keep in mind every universal remote is different and will have different steps to follow, but all generally work the same way.
At this point you'll want to just try the POWER button on the remote. If your TV turns on it means the code you entered is the correct code, or at least close to the right one. If it's not the exact correct code some of the other buttons won't work or will command your TV to do the wrong thing.
If your TV does not turn on with the first code you tried, you will need to program the remote with on of the other Philips codes. Just follow the same instructions you used to enter the first code and try another one from the list. Try the POWER button with each of the codes used until the TV turns on.
If none of the Philips codes work you will need to follow the universal remote's instructions to cycle through all of the codes (I have had to do this before). There should be another section of instructions that tell you how to do this. Again, try the POWER button for every code until the TV turns on. Once the TV is on, you will want to follow the instructions for the remote as normal to find the exact code preset that will work correctly with your TV.
If all else fails you might want to purchase a remote that is at least newer than the TV you are trying to operate because an older universal remote may not have the correct preset for a newer device.
I hope this helps! Good Luck!
Dec 15, 2015 | Philips HTL2101A/F7 40 Watts Sound Bar
Need code for philips tv using emerson universal remote
2749,2718,2745,2701,2783 are the codes to check with Philips brand TVs. If you wish to get more details, check this site. Pull up older posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter."
Mar 30, 2013 | Emerson Televison & Video
I am using a Philips SRU3003WM/17 Universal Remote with my Sylvania TV Model number 64119E. When programming the remote some strange numbers appeared on the screen and now I cannot get them off. The...
Well your Philips universal remote control comes with a list of codes for devices by brand name.
Find the first code for the brand name and type of device you wish to program. Turn all of your devices off, and then manually turn on the device you want to program.
Press the Setup button on your the universal remote and continue to hold it down until the indicator light stops flashing and remains solid. Release the Setup button. Press the Mode button for the type of device you want to program on your Philips universal remote, such as the TV.Release it immediately and make sure the indicator light is illuminated. Enter the first possible four-digit code on the universal remote, and then press another button on the remote to see if the device is now programmed, such as the volume control or power button. If the device responds, you have successfully programmed your Philips universal remote. If not, turn the device off and back on and follow the steps again using the next code on the list. Repeat until the device successfully responds.
If your TV code is not listed on the manual then you can use the Remote Using Code Search Option -
Your Philips universal remote has a built-in code search feature that will find the correct code for your device. This process may take longer than using direct code entry, but can be helpful if you do not have access to the code list or if the brand for your device is not listed.
Make sure all of your devices are turned off, and then manually turn on the first device. Press the Code Search button and hold it down until the red indicator light stays illuminated. Press the Mode button for the type of device you want to program on your Philips universal remote, such as the TV button.  Release it immediately and make sure the indicator light is illuminated. Press either the Channel button until the device responds. You may have to press the button up to 300 times. Each time you press the button, the Philips universal remote tries a new code. When the code works, press the Mute button on the Philips universal remote and the code will be stored.
I thing you wrongly do the second option that creates the problem. No issue, if your tv code not listed on the manuals then you can go with the second (code search) solution. Please post comments for further help or information.........
Good Luck!!
Thanks
Jul 31, 2010 | Televison & Video
Need to program my tv and dvd player to the remote
Please follow the steps below
Program the First Device by Entering Direct Codes
1.Turn all of your devices off, and then manually turn on the device you want to program.
2.Press the Setup button on your the universal remote and continue to hold it down until the indicator light stops flashing and remains solid.
3.Release the Setup button
4.Press the TV button.
5.Release it immediately and make sure the indicator light is illuminated.
6.Enter the first possible four-digit code on the universal remote, and then press another button on the remote to see if the device is now programmed, such as the volume control or power button.
7.If the device responds, you have successfully programmed your Philips universal remote.
8.If not, turn the device off and back on and follow the steps again using the next code on the list. Repeat until the device successfully responds.
How to Program a Remote Using Code Search
6.Press either the Channel button or the Play button until the device responds. Each time you press the button, the Philips universal remote tries a new code.
7.When the code works, press the Mute button on the Philips universal remote and the code will be stored.
To get the universal remote codes please visit below solution
http://www.fixya.com/support/t5395701-universal_remote_code_phillips
Thanx
Jul 27, 2010 | Philips Universal PH301S Remote Control
Philips universal remote codes
Here are the remote codes for virtually all TV sets; follow the instructions for setting up the remote. You only can use the remote for ONE device:
https://wabash.com/wp-content/uploads/2015/11/ADB-Programming-Guide.pdf
Sep 21, 2017 | Philips Televison & Video
I need the code for a Philips SRU3006WM/17
Codes listed for Sony DVD players are 0300,0400,0500,0541,0200,0540. Hope this helps due to no listing for Blu-Ray players.
Mar 29, 2009 | Universal Remote Control 6-Device...
I have a philips universal remote and an Rca Tv how can I program
code list is also listed
Great News!! We can program most Philips Universal Remotes with Automatic Code Searh. Here's how it works on most of our remotes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
The above assumes that you want to store the VCR you want under the VCR but, Cable codes under the CBL, etc
Note: if the device does not have a chat channel at a button, you should Play (VCR only) or Power instead.
Here is a Code List on PDF that shoud be universal for most remotes. It worked for me.
http://www.remotecodelist.com/remot...ps-Magnavox_PM525S.pdf
Hope this helps you out, good luck.
Nov 28, 2008 | Philips Magnavox Learning Universal Remote
RCA Universal Remote Code
Here are the codes for Philips. If these do not work you have to use the code search feature.
Philips........002,006,007,010,011,013,016, 033,035,037,038,043,066,073
Programming a Device using CODE SEARCH
1. Manually turn on your device (TV, VCR, Laserdisc Player, Satellite Receiver, Cable Box or Audio Equipment).
2. Press and hold CODE•SRCH.
3. Press and release the device button you want to set up (TV, VCR1, VCR2•LD,
SAT•CABLE, or AUDIO).
4. Release CODE•SRCH.
5. Press POWER repeatedly until the device turns off (you may have to press up to
100 times).
6. Once the device turns off, press and release ENTER.
7. With the device on, press another button,
for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-7.
Nov 12, 2008 | RCA Universal Remote Control
Philips HTS3450 System Logo
347 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
