Nexxtech remote I bought a nexxtech remote for my tv and programmed it. It worked fine with the tv and cable until i dropped it yesterday and now it isn't working and I don't remember how i programmed it to begin with. I tried new batteries but still now when i try to turn off the tv or do anything with the remote all it does to the tv when its on is interrupt the sound for a split second while im pressing the button.
  • TammieTam Mar 28, 2009
    I bought this Nexxtech universal remote as it said it would operate my viewsonic tv. It gives two codes 0042 and 0076 but they don't work. I even tried going through the 300 channel ups. Can anyone help me who may be using different codes that work?
I had the same problem, check out this website
http://download.orbyxelectronics.com/orbyx/1519001/manuals/manual.pdf
Posted on Jan 03, 2008
6ya staff
SOURCE:
My remote was working fine until i moved. I have Direct Tv and the remote from Direct Tv works on guide. I bought a new remote from Magnavox but it doesn't work my tv. what should I try? '
You have to program the remote control to synchronize with TV. If you wish to get moredetails; codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
Mar 17, 2013 | Televison & Video
Hi can you help me please , ive bought a polaroid lcd tv model no p40lcd12 . ive looked everywhere on the net for the remote code for my sky + remote. sky dont have it listed .has anyone got it .would...
I bought the same TV yesterday and I've used code 1065 to program my sky remote, which worked fine. It's thanks to the answer relating to Mitsubishi and TiVo cos I used a Mitsubishi code!! Hope it works for you.
Sep 23, 2012 | Televison & Video
I have a Nexxtech IT009 remote and a HTS Dish Network converter box. What is the remote's codes and how do I program them?
http://www.tivocommunity.com/tivo-vb/showthread.php?s=&threadid=128743
Above are all the codes for the HTS box,one of these should work with your remote.
Nexxtech codes below.
www.jascoproducts.com/support/download.../RemoteCode-4-digit.doc
Try using the code search to programme your device.
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold the P (Program) button until the red indicator stays on. Release the P button.
3. Press and release the desired mode button (TV,VCR, etc.). The red indicator blinks, then stayslit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device to be controlled changes channels. If you accidentally overshoot the desired code, press the Channel Down button to backtrack through the library until the device changes channels. Pressing Channel Up changes the direction to forward again.
5. Press and release the Enter button to set the code.
If you still need a code list email, [email protected] or call 1-866-363-3059.
Aug 13, 2010 | DISH Network IR Remote Control
Universal remote code
I just bought one of those remotes to use on a Magnavox VCR because the buttons on the original remote are difficult to read (grey numbers on grey buttons).
The TV codes for Panasonic are: 0171, 0148, 0054, 0170, 0062, 0374, 0381, 0437, 0950, 0003, 0070. Good luck.
I had no luck with any of the codes given, so I tried the "Programming with Code Search" method and it worked.
1. Turn ON the device manually.
2. Press and hold the "P" button until the red light stays on.
3. Press and release the desired mode button (TV, VCR, etc.) The red light blinks, then stays lit.
4. Press Channel Up button repeatedly (up to 300 times) until the channel changes. (If you accidentally overshoot, press Channel Down to backtrack.)
5. Press and release the Enter button to set the code. (Mine doesn't have an "Enter" button, only an "ENT" button the left of the "0" and that didn't work, but I found the "M" button in the middle worked.)
Nov 09, 2008 | Televison & Video
HOW DO I REPROGRAM MY NEXXTECH 4 IN 1 UNIVERSAL REMOTE CONTROL.......
Step 1: Click and hold "P" till red light remains on
Step 2: Click TV
Step 3: Click "Power" until TV shuts off
Step 4: Click "M" to save the setting
Step 5: Repeat steps 1 thru 4 on all devices
Oct 13, 2008 | Televison & Video
I have a nexxtech universal remote and a philips dvd player, How do I program, lost the manual
i both a universal remote control from nexxtech for my electrohome tv a month ago .
And its not working anymore , i lost the code to reprogram it . Can you help me to get that code
Sep 02, 2008 | NexxTech PDN-0705 Portable DVD Player
NEXXTECH 2 IN 1 BIG BUTTON Universal REMOTE CONTROL TV code for sansui tv
Have a solution for you.Turn your TV on then Press and hold 'P' on remote until light stays on. Press device to be controlled (TV/Cable) light will flicker but stay on. Now keep pressing channel up (up to 300 times) until device changes channel. Then press Enter to save code. Hope this helps
Jun 08, 2008 | Big Button TV Universal Remote
My Sharp Aquos TV has stopped responding to remote control(s)
Unplugging my TV for 15 seconds (longer actually - at least a minute) made the remote and the satellite TV remote both work again with the TV.  Thanks for the tip!
May 14, 2008 | Televison & Video
Codes for a nexxtech tv remote control 3 in 1
Wiki works, folks.
http://kbase.x10.com/wiki/Four_Digit_Universal_Remote_Code_List
All the codes for Nexxtech Universal Remotes, including Panasonic.
Cheers!
Dec 28, 2007 | Sanyo PLC XU35 Multimedia Projector
Programming my nexxtech 3-in-1 remote control
looking for instructions for  remote control nexxtech 3 in 1 universal
Oct 28, 2007 | Televison & Video
Televison & Video Logo
735 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
