Polaroid I533P Digital Camera
Polaroid i533 digital camera
shared by 11 users
posted by shannonjl on Jan 03, 2008
My daughter has this camera bought less than 3 months ago- It makes 3 beeping noises and turns off. We replaced memory card and batteries- test them in my camera first to make sure they do work and they do, but not in hers- Please help..... Is there a way to reset the camera? or should we just return it?
thank you,
Shannon
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
10 Other Users Have The Same Problem
Posted by xmoonakx on Sep 14, 2008
my camera occasionally decides to turn on and work fine (beside the fact that it takes bad pictures) usually, however, when i press the power button the light blinks green once and does nothing. i contacted customer service and sent in my camera to be fixed. when i finally got something back, they said the camera was defective and they gave me a brand new one for free.
however, now that i have the new one (which i take really good care of) it does the same thing. now i have a great desire to chuck it against the wall.
Posted by beccks_dance on May 05, 2008
I have had this camera for only a few months-my previous Polaroid i531 was defective so they sent me this new one. Now whenever I put fully charged batteries in, it beeps three times and shuts off! I've tried different batteries & memory cards. Nothing works! I'm done with Polaroid.
Posted by Guest on Mar 23, 2008
I took our recently purchased i533 with me on my first ever ATV adventure to the Little Sahara sand dunes in Oklahoma. I had used this camera around the house for sporting events and various other reasons and have aways been happy with it. I was really excited to capture my much anticipated vacation.
After an 8 hour drive I was ready to go. I put fresh batteries in the camera and headed out to enjoy my experience. I took a picture and everything worked fine. I went to take another picture about 5 minutes later and the cameras screen came on momentarily and then turned off, followed by three beeps. I thought it was the batteries, so I switched in three more sets. All of them had the same results.
I am going to contact Polaroid and see how to fix the problem. I am very unhappy about this situation. I hope that Polaroid stands behind their product and helps me rectify this situation.
Posted by Guest on Mar 22, 2008
Girlfriend took it with her on a trip and when i went to turn it on it comes on for about a second or two, beeps three times, then dies :(
Posted by poopybutt on Mar 22, 2008
I dropped my camera and the lens seems to be uneaven and stuck.
When I try to turn it on it beeps three times and then turns off.
What should I do to fix it??
Best Solution
posted on May 04, 2008
FixYa! (100)
KaisMom
Rank:Apprentice Apprentice
Rating: 96%, 4 votes
I noticed that mine did the same thing and "cheaper" batteries was the cause of it, I had bought some Energizer and Duracell and it was fine. I bought some rechargable batteries and never had the problem again
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Polaroid i533 digital camera:
I don't want to Accept this solution
Best Solution
posted on Jan 11, 2008
Helpful (85)
IKnow
Rank:Wiz Wiz
Rating: 81%, 43 votes
Best to return it, recomend you get a Casio, Sony or Canon
Thank You!
Solution #3
posted on Mar 19, 2008
Thanks for Trying (70)
nils96
Rating: 79%, 10 votes
Here is how I fixed this problem. I grasped the lens around the base (larger part) like you would if you were going take off a beer bottle cap.
Very gently while sliding my thumb and index finger around the lens, I rocked it back and forth. DO NOT TRY TO TWIST OR PUSH,.....It felt like it "popped" back on track.
My assumption was it was probably hit from the side, and could not retract, once it was rocked back on track, it worked fine. It felt like it loosened a tiny bit as well.
Good luck.
Thank You!
Can you Help with these Digital Cameras problems?
I have a Lexar 256MB SD memory card in my i733 camera....
i have a digi cam- Polaroid i533, i have to replace its...
I take a picture. File Error comes on the screen. What...
when i turn the camera on it will not show any of my pics...
10 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Mar 22, 2008
i droped my camera and the lens will not come out again.
what should i do??
it beeps 3 times and turns off also
Comment by jkerr8, posted on Mar 21, 2008
I called the Polaroid customer service line. The guy I talked to said he had no idea-he would have to see the camera to diagnose the problem. Then he told me that, since the camera was past warranty, I couldn't mail it to him. Needless to say, I won't be buying any more Polaroid products.
Comment by Guest, posted on Mar 16, 2008
My camera was less than a month old when it too started having the exact same problem. No solution so far...
Comment by Guest, posted on Feb 16, 2008
i have the same problem. it's a good camera.. it just started out of nowhere i didnt drop it or anything.
Comment by jkerr8, posted on Jan 19, 2008
I have exactly the same problem. Three beeps and then . . . nothing. Has worked fine for a year up until now.
Loading problems.
Repair Service
Find Digital Camera Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
