Jenn-Air 36 in. CCG2523 Gas Cooktop
Clicking noise on gas oven
posted by lucy1030 on Jan 03, 2008
I have not used my oven in a week and as I am cleaning my kitchen, a continous clicking noise began similar to how it would click as I am about to turn on the burner except in this case the clicking noise will not stop. Would could be causing this? Please help!
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jan 04, 2008
FixYa! (100)
phixer
Rank:Wiz Wiz
Rating: 88%, 26 votes
when you were cleaning the cooktop did you remove the knobs and spray ,did any liquid fall were the knobs was taken out from. if yes you wet the burner switches it should dry in a day or so depending on what you used to clean it with to speed up the process remove the knobs unplug cooktop if possible and wipe the switch area if this doesnt help take a blow dryer and dry them that way or try good old fashion wd40 it repels water ,spray each one till yu find the culprit it will stop right away.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on clicking noise on gas oven:
I don't want to Accept this solution
Can you Help with these Kitchen Cooktops problems?
Kitchen Cooktops
I have jenn air gas cook top stove that won't stop...
None of the ignitors are working. I check the power source...
what should the flame look like ? my flame is blue, with...
Brand new installation and Ignitor stays on in all...
The middle burner will not light. The valve will not turn...
Loading problems.
Repair Service
Find Kitchen Cooktop Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
