Question about Philips Magnavox 51MP392H Rear Projection Television
Ringing sound I have a 60in. and after a couple of minutes on it will start to have a ringing sound even on mute.
  • Anonymous Jan 04, 2008
    I'm having the same problem also, what do you mean by reseating the fly back? Do you mean removing it and reinstalling it? (cleaning)
  • kingbuster Jan 04, 2008
    I'm having the same problem, What do you mean by reseating the fly back?
    Are you saying to remove and replace it, maybe cleaning it?
    President:
  • 4,402 Answers
I would first try to located inside where it's coming from most of the time it's the high voltage fly back needs to be reseated
Posted on Jan 03, 2008
Uniden Model EX 14560 Ringer off How to put ringer on
Here some solutions for your problem + a link to the user manual.
**Selecting the Ring Tone and Volume
Your phone has five different ringer tone/volume combinations you can choose from.
To select the ringer:
1) With the phone in standby, press [vol/ / ] or [vol/ / ].
2) The phone will sound the different ring tones at different volumes. To turn the ringer
off, select RINGER OFF.
3) When the phone sounds the ring tone and volume you wish to use, press [end].
**Temporarily Mute Ringer
If the handset is off the base while an incoming call is ringing, simply press [end] to mute
the incoming ring. The ringer will sound with the next incoming call.
Note: You can only mute the handset ringer if the handset is off the base when the phone starts
ringing.
Adjusting the Earpiece.
**Here is also a link to the phone manual http://www.uniden.com/pdf/EXI4561om.pdf
May 18, 2011 | Uniden Cordless Phone
How do i mute ringing on my e71?
To mute the ringing tone instead of answering a active call,select Silence.
or u can try the following
To set a mute ringing tone for a profile, select Options >
Personalise > Ringing tone. Select a ringing tone
from the list, or select Download sounds to open a
bookmark folder containing a list of bookmarks for
downloading tones using the browser. Any
downloaded tones are saved to Gallery.
To play the ringing tone for a selected contact group
only, select Options > Personalise > Alert for, and
select the option similar to none,etc...
May 24, 2010 | Nokia E71 Smartphone
60in Sony KDS-60A2020 LCD rear projection picture goes on and off
yes replace the lamp, sony units have certain specs that the lamp must meet to operate correctly. If the Lamp you purchased is made by LTI, these lamps do not last long as they are poorly manufactured. Look at the bulb and see who is the maker if its says LTI then replace with a Phillips brand that meets spec's for sony.
Jan 30, 2010 | Sony KDS-60A2020 60" HDTV
My Sony 60in Wega Rear Projection is going dark every few minutes and the sound goes out. Can't find the owner's manual. What do I do?
Your suspect is the lamp. You will need part number A-1085-447-A....If the lamp fails to light or goes out, so will the sound.
Nov 11, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
LG evV Touch seems to be muted when volume is set to High
just have your phone on and pull the battery(MAY LOSE SOME DATA RINGTONES,PICTURES,ETC
Aug 20, 2009 | LG enV VX9900 Cellular Phone
HOW DO YOU MUTE A NOKIA 8800
To mute the ringing tone, select Silence. Then either answer or reject the call.
you can also mute sound during call.
Mar 05, 2009 | Nokia 8800 Cellular Phone
Need short cut for muting ring, also is there a vibrate mode?
If you hold down the * key (lower left) for a couple seconds it will turn vibrate mode on.
Dec 23, 2008 | LG CU515 Cellular Phone
Phone is slow
First backup all of your data...After that format your handset...
For format goto Start -> Settings-> System-> Click Clear Storage ...I hope your problem will solve
Jul 31, 2008 | HTC P3300 Smartphone
Philips Magnavox 51MP392H Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
