our Maytag Neptune TL FAV6800AW doesn't work. you cannot change cycle settings, it turns itself on and off while washing, the water doesnt drain and it constantly BEEPS! HELP!
From what you describe I feel you have a Control Board failure.If you haven’t tried this try removing the 120VAC power plug to the washer then repower back up.If that doesn’t clear the issue and you decide not to do further troubleshooting it would be time to call in a service repair company.I would call Maytag for an authorized Maytag repair service in your area.Some parts like the Control Board may still be under warranty (5yr).Warranty info is in the SM link I’ve attached.The number to call is 800-688-9900.Maytag will need your model number and serial number, that info is located on the back right top side of the console. The Service Manual for reference. Sears Parts Direct for reference. Good luck and post back if you have questions.If you can get into Service Mode you might be able to turn on the drain pump in and pump out the tub.Let me know if you have other questions. Rich aka dh1200s on the forum.
Was this helpful?
Yes
No
Popular Solutions for Maytag Neptune FAV6800AW Top
My clothes are stuck in my neptune. It won't drain and the door will not unlock. How can I restart...
(More)
My clothes are stuck in my neptune. It won't drain and the door will not unlock. How can I restart it?
my maytag washing machine stop working totally mid cycle. I'm not getting anything when I turn and...
(More)
my maytag washing machine stop working totally mid cycle. I'm not getting anything when I turn and pull out the know
My Neptune TL is not completely draining. I've got the tub out but am having trouble getting the big...
(More)
My Neptune TL is not completely draining. I've got the tub out but am having trouble getting the big bolt off the bottom to open up the tub. I've checked the pump and lines and they are clear. I can still here water in the tub so I would like to take it apart to inspect
