Mower sometimes will not start. Has new battery that is maintaining charge. Sometimes nothing will happen when I turn the key. Could it be faulty ignition switch? Solenoid?
Re: mower sometimes will not start. Has new battery
You have to use a volt meter and test the ignition circuit to find out where the voltage stops. If you have 12 volts going in to and out of the switch, then switch is good
Make sure your new battery is charged up first. New batteries will die sometimes. Make sure your cables are tight and clean and your starter could be at fault if all that work it won't turn over. Make sure your engine is not seized as well.
If the battery is below around 11.8 volts it never will charge. The charging systems on these mowers are made to "maintain" the charge. Check the battery, if below 11.8 volts charge the battery with a battery charger. Then see if the mower will maintain the level. If not, you may have a bad battery. Your local automotive store can check it for you.
just purchased 1995 says seller, serial # says 1990, 312h kohler wheelhorse 157 hours, royaly maintained, new condition runs great when it starts,turns over great, spins fires spins fires over and over then back fires thru carb, flames this no start, help going to snow tonight
Often mowers come with batteries which simply do not have the cranking amps to do the job. Have someone look at your mower and see if your attery has the sufficient cranking amps.
Check your battery water level if it's not a sealed battery. Some small batteries require you to fill them with both acid and water, some with water only when new.
If that is not a issue then you are most likely running on your battery alone. You need to check your charging system. Check your battery voltage when the unit has not run for at least an half an hour. Then check it when it's running. The voltage should be higher. It should be 12.5 to 14vac. Lower means your alternator is not working or a fuse is blown in your charging system. Higher means your voltage regulator went bad and the higher voltage will cook your battery in time. The voltage regulator is usually in the alternator and can not be changed without replacing the alternator. Check your parts diagram. If it lists a voltage regulator then you are in luck.
