Question about GE WSM2700W Unitized Spacemaker Washer and Dryer
GE WSM2700RDWWH Spin/Drain Intermittent Issue
This washing machine was purchased in July 1995 and has started having an intermittent problem this year. The problem seems to occur during the spin and rinse cycle. When the cycle is complete, the contents are soggy wet and the soap has not been rinsed out. The problem does not occur during every cycle -- in fact, the last three cycles have been just fine, but the cycle previous to those three had the problem.
Five technicians have been out to investigate the problem and they can not identify the cause. In an effort to do something, they replaced the washer timer and pump, but the problems still persists.
I'm not sure what else to do. Any help would be much appreciated.
Megan Crunkleton
New York, NY
[email protected]
Does not agitate
Posted on Aug 26, 2008
6ya staff
SOURCE:
Ref: 2008 Kenmore Elite Washer Model 110.28032700 Sub: Intermittent spin problems Machine gets stuck between wash and rinse ( confirmed no water in tub ) and sometimes between rinse and spin (
If this machine has a mechanical motorized dial (old style), then it might have worn contacts or a defective motor in the clock. If it's electronic, then it could be a computer related issue.
Dec 29, 2014 | Kenmore Washing Machines
Neptune washer mah3000aww skips to spin cycle and wont drain
It sounds like the "repaired" main control board is still the issue with it being intermittent.
Nov 20, 2012 | Maytag Neptune Washer
GE washer won't complete cycle
there are contacts inside timer which may not be working properly. in any case they are not repairable.
Oct 28, 2009 | GE Washing Machines
Intermittent water on floor
Check the inlet valve hoses, even if inlet is at the back, the water may drip down and flow on the front part on the machine. There you also have the PUMP, a faulty pump may leak intermittently.
Here you get all diagrams and parts for your appliance.
Sep 25, 2009 | GE WJSR2070B Top Load Washer
I have a GE Profile Prodigy top load washing machine. Sometimes the spin cycle does not spin, sometimes it spins. It makes a clicking noise during gentle cycle
The gears maybe going out. Sometimes it is able to engage in the other direction which the spin, sometimes not. Washing machine have complex gears that in one way agitator works, and the other the gear locks to turn the whole tub. The clicking noise is probably the locking mechanism in the gears that has caused the whole intermittent problem.
Jul 01, 2009 | GE Profile Prodigy WPSE4200A
110.26842692 series 80, tries to spin while pumping out.
correctm the lid will need to be closed to spin/drain water, if your experiencing an issue that it intermittenly stops during thiscycle, possible that the lid switch is GOING bad, and not always making contact.
Dec 11, 2008 | Kenmore 24032\24036 Top Load Washer
Neptune won't advance from Rinse to SPIN
If the clutch fails the first thing noticed is a UC or DC error displayed and there is no drain or spin.
If you are seeing the above error and having a problem with spin and drain then the most likely cause of this is the clutch. The clutch fails to lock down the spinners and the basket is unable to go into spin and without a 90 RPM there is no drain.
Replace the clutch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question(@#$^
Aug 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
GE Washer
have they checked the door lid switch?..it could be intermittent also because if the switch is not close, it would not drain and spin anymore. try to bypass the switch temporarily by shorting it out then use it . becarefull because you can now open the door while it is spinning ad it is very dangerous.
Feb 17, 2008 | GE WPRB9110WH Top Load Washer
No final extract spin
P-bass, sounds like your problem is in the lid switch actuator that mounts to the bottome side of the top. I have found a bunch of these actuators just missing making the switch. Therefore the intermittent problem. Solution is to just bend it enough to insure making the switch on every closure. Catriver..post back.
Nov 29, 2006 | Whirlpool CAM2752KQ Top Load Washer
GE WSM2700W Unitized Spacemaker Washer and Dryer Logo
395 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
