Carrier 52CE-307---4 Comfort Series Cool/Electric Heat, 7000BTUH, 3.4KW, 265V PTAC Air Conditioner
Problem for Carrier 52CE-307---4 Comfort Series Cool/Electric Heat,...
Mosture on windows to high or to low setting
By candemachine on Nov 02, 2009
mosture on windows to high or to low setting on Comfor Air 700 humidifier
Solution #1
posted on Nov 02, 2009
Not Rated)
VtToolMan
Rank: Guru
Rating: 97%, 602 votes
Hello, If you're getting moisture on the inside of your windows while using your humidifier, you've got the setting too HIGH and you should turn it down at least 2 setting levels to begin with.
Whenever you're using a humidifier, the amount of moisture that it will put into your air will vary depending on how warm or cold the house is. Also, it will depend on whether you not you're using a wood stove to heat with too, as a wood stove will dry out the air faster than conventional heating devices (forced hot air furnance, electric baseboard, etc.).
A wole house humidifier also will vary depending on the outside air temperature changes, so you won't need as much humidification on mild days, as you will on very cold days such as when the outside temps are below freezing.
The good news is that you've discovered the simplest way, for most people, to determine whether to turn your humidifier UP or DOWN - If you're getting moisture on the inside of the home's windows, turn it down, if you're not, you can turn the humidifier up slightly until you just see moisture starting to form on any of your windows (typically this will occur in the colder rooms first), then just turn the setting down one setting level.
The great thing about having a whole house humidifier is that you can actually save on your heating costs, as the moist air makes you feel warmer and will provide you with a more comfortable home in the winter months.
I hope you find this Very Helpful and best regards!
Was this helpful?
Yes
No
Popular Solutions for Carrier 52CE-307---4 Comfort
Questions and Unsolved Problems for Carrier 52CE-307---4 Comfort
Do you recommend Carrier 52CE-307---4 Comfort Series Cool/Electric Heat, 7000BTUH, 3.4KW, 265V PTAC Air Conditioner?
Answer
Answer
on my window airconditioner I am constantly getting a thick ice buid up. I have cleaned the filters... (More)
Answer
I live in a manufactured home. When I turn on my heat on my amana it does not start.
Answer
I have an error code of CH 26 on my LG airconditioner 524AHN can you help me diagnose the problem.
Answer
I have a Split Type Room Air Conditioner. When i turn on the unit with my remote control, the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Carrier 52CE-307---4 Comfort...:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
