Question about Philips HTS3410D/37 700W DVD Home Theater System System
Standy by button flickers on and off
The standby button is flashing off and on. None of the buttons on the unit or on the remote work. i took the cover off and i hear a constant ticking noise somewhere near the fuse and plug is. when i press the stand by or open button the fan cuts on when i let go the fan cuts off. help please
  • Anonymous Jan 06, 2008
    I have the same problem. And, the fuse looks good. How can I fix this? I may take it to a shop. I don't know if the device is still under warranty.
  • rainbowmich Jan 14, 2008
    yep. same problem here. and even after unplugging it the noise continues for several seconds. the fuse looks o.k. I dont understand. help.
  • 3 Answers
I solved this problem on my HTS3410D.
Inside there are two circuit boards, the power supply board and the audio/video board.
  • First, unplug your unit and let it sit for a few hours.
  • Now open the unit up, and unplug all of the connectors going to or from the power supply board. You can easily tell which board is the power supply board because it's the one the power cord plugs into.
  • Unscrew the four mounting screws that hold the board to the case.
  • Using a pair of needle-nose pliers, squeeze the two white plastic clips that hold the board to the case (one at a time), while gently lifting the board away from the case.
  • Now that you have the board out, feel the tops of all the capacitors (they look like this). Healthy capacitors should have a totally flat top. (There is probably one that is covered in some sort of heat shrink, so you can't feel the top.)
  • One capacitor most likely has a slightly bulging top. That is the culprit.
  • Using a soldering iron, carefully remove the busted capacitor, making sure to note which side the stripe is on.
  • Buy a replacement capacitor at Radio Shack or www.digikey.com that has the same capacitance (e.g. - 1000uF) an equal or greater voltage, and an equal or greater maximum temperature.
  • Insert and re-solder the replacement capacitor in the same orientation as the one you took out, then trim the excess leads.
  • Reassemble your system, and you're done.
The capacitor that died on mine was 1,000uF, 16V, 105°C. It was located fairly close to where the power cord comes in to the board. I replaced it with a 1,000uF 50V capacitor, and the system powered right up like a champ. The entire process took me about an hour.
I hope this helps some other people have similar results.
Posted on Mar 20, 2008
Dvd recorder in standy wont work - blue standby light showing!
The main power supply board has the fault. It might be replaced. It is best to replace as card basis, rather than making 'surgery' to it.
May 30, 2012 | Televison & Video
Just purchased a Magnavox dvd recorder MWR10D6 and hooked it up. The power light comes on but it won't let me use setup or timer
Try disconnecting from power and connecting back, if it does not fix it bring it back, it is faulty.
Apr 08, 2008 | Televison & Video
Message Fan Check visible then 'protection' then powers off
my system keeps turning its self off then the standy keeps flashing...does any1 no why???thanks
Nov 20, 2011 | Audio Players & Recorders
Tv has no power button.. remote works cant turn on tv with remote (not linked up)
Unless the TV is in the standby position there will be no power to the processor circuit and IR detector which is needed to process the incident signal from the remote to the processor for action.
If there is no standy check the power and the processor +5 which is most critical.
Nov 07, 2011 | Sharp G0797cesa Remote Control
Standby light stays red and will not turn unit on.
Try to reset the macroprocessor. Unplug the unit from AC, hold both buttons SPEAKER A and SPEAKER B and plug the cord in outlet. After display flashes several times release the buttons. No result? - repair shop.
Apr 05, 2009 | Denon AVR-1906 Receiver
SONY NAS-EH35HD Giga juke hi fi Standby light flashing
i have similar. All gone off and red light flashing. Did you get yours sorted?
Mar 27, 2009 | Sony Audio Players & Recorders
Marantz SR6001 AV Surround Receiver - Blinking Standy Light
I have exactly the same problem! Sometimes when I turn the input dial it comes back on but this time it is out for good. I have tried re-wiring and unplugging etc. nothing seems to work.
Jan 21, 2009 | Marantz SR6001
How to turn off standby mode
Try this:
On the top of your remote near the power buttons there are a series of buttons that have names under them such as "TV" and "DVD". Press and hold one of those buttons for about two seconds.
Jul 17, 2008 | Philips FR975 Receiver
Unlocking my DVD Player
Try this,it should work....Rod
To change the current region setting on this player
1. Press the Standby button on your remote control to place the unit into Standby
2. Press the Standby button on your remote control to turn on the unit
3. Press the Open/Close button on your remote control to open the drive tray
4. Press the Clear button on your remote control
5. Press the 1 button on your remote control
6. Press the 3 button on your remote control
7. Press the 6 button on your remote control
8. Press the 9 button on your remote control
9. Press the 0 button on your remote control
10. Press the Open/Close button on your remote control to close the drive tray
11. Press the Standby button on your remote control to place the unit into Standby
12. Press the Standby button on your remote control to turn on the unit
Jul 16, 2008 | Durabrand Televison & Video
Durabrand LEDVD0701 dvd player
Taken from another site in case you still need to unlock it.
The Pacific hack works for this one!
Multi-Region Hacks for Pacific DVD-1001
Oct 20, 2007 | Televison & Video
229 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
