Question about HP DeskJet 9800d InkJet Printer
I need a printer that will be able to operate under both systems they are connected to a print share hub
  • HP Expert
  • 424 Answers
Driver download link: HP Deskjet 9800d Printer Driver
Posted on Feb 03, 2010
I cant print wireless on my hp Laserjet 1015 Printer. I have it like a Directed connected shared printer to my PC. By the way, the operative system of my pc in which i have it connected is XP, and it does...
With that, you need to install the printer into your windows 7 computer and windows vista computer.
Even though the printer is installed into your windows xp computer wirelessly and set up as shared printer, you still need to install it on to your other computer because you need to install the driver and other printer's software to maximize the features.
Since the printer is already connected, you just need to run the appropriate installation package, the one that's compatible with your Operating System, and install it via Wireless or via Network. For the correct installation package. You can download it from the hp website and check the Support and Driver's section.
Jun 22, 2011 | HP LaserJet 1015 Printer
Unable to find printer sharing for mfc6890 over window xp
To set up printer sharing in your home network, you need to configure printer options in the control panel of Windows XP Operating System. You could get a menu while right clicking the printer icon in the Control Panel. From this, you need to select the sharing option. You also need to make sure that you have enabled printer sharing option in the network card properties. To connect a printer in the network you need to set an IP address for your printer. If you have any troubles with printing with your printer in the network it might due to the errors in the network. So, you need to make sure the network connection.
Apr 06, 2011 | Brother MFC-6890CDW Printer
Cannot detect other printer in remote desktop connection
Hello my friend, regarding on your problem kindly check your system particularly your windows 2008 server OS. Kind reinstall the printer drivers then then shared it. Then after you share the printers kindly check the ip address of your windows server 2008 OS then go to the workstation Computer then click start button found in your task bar manager then click run. Then kindly type the "\\IP of your windows server 2008" where your printer drivers installed then enter. As soon as you can log in the Windows server 2008 menu environment then if you can find or see the printer icon then click the printers icon then right click then click connect. Let the system automatically installed the printer driver to your workstation computer. then as soon as your system finished installed the printer drivers then try to run and print if you can now print using network LAN.
Hope this solution able to solve your problem. If you need more assistance kindly rely to this post.
Thank you.
Jul 17, 2009 | Office Equipment & Supplies
Connecting a network printer to 2wire 2701HGV-w
This is a little tricky technically it your printer isn't made to go onto the network, but you and do one of to things... let me start with the most cost effective way and that is
1. Hook your Printer up to a computer that is already on the network and then go into windows and SHARE that printer giving access to all the computers to print to it that you need to. I don't know what Operating System you have so your going to have to give more information to get clarification on exactly what you need to do in the Operating System to share the printer. The CONS of this approach is that you can only print to that printer when that computer is on. So if you want to have continuous ability to print to that printer you will have to keep your computer on.
2. You can get what they call a Print Server... and connect it to your printer and your network.. turning your printer into a network printer. Of course you might need to get more detail depending on what Print Server you choose. The Cons of this approach is that ofcourse your going to have to buy more equipment... but the pro's are you won't have to keep other computers on in the network to print to it. One last note you will find Print Servers in the store where you find Routers and Hubs.
The best of luck to you... and I hope this Helps... after you decide which way you want to go you might want to contact me or one of the other techs to get more percise approaches to installing your equipment... but we will need to know you Operating System, and the Print Server... if you go that route. Good Luck! I hope this works for you!!!
The Man Inside the Machine
May 20, 2009 | 2wire (1000-000057-000) Modem
Printer sharing wirh USB hub
I would connect the printer to the main computer, network the 2 computers and enable printer sharing. The only draw back to this is that the main computer will have to be on in order for the other to print. Vista makes this easy to do.
Jan 31, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
Use two computers with one printer
Printer Sharing (This is good for Windows 2000, XP and Vista)
Sharing will be very easy if your network is working.
You need to consider the computer where the printer connected as the "Host" and the other computer that wants to print to that printer as the "Client".
Before you do such sharing, you need to acquire each computer's IP address.
You can do it by accessing MSDOS Prompt and typing in ipconfig/all. Write down your IP addresses and the share name on a paper.
For your Host:
Install the driver, make sure that you can print on direct bi-directional connection (such as USB).
Go to Control Panel >Printers and Faxes* >Sharing >Share this printer >Type in your share name, good example is PRINTER (this is case sensitive).
For your Client:
Install the driver, make sure that you can print, same with the Host.
Go to Control Panel >Printers and Faxes* >Properties >Ports >Add Port >Add local port type in \\ (the IP Addressof the Host) \ (share name), click OK.
ex. \\\PRINTER (watch your backslash, no spaces)
*Term used is "Printers" for Windows Vista and Windows 2000
Oct 23, 2008 | NetGear FS105 5x10/100 Mbps Networking...
Network printe on vista
Accessing a Shared Printer To access a shared printer from a computer running Windows Vista, do the following:
  1. Click Start, and then click Network. The Network window displays a list of computers in the workgroup of the computer.
  2. Double-click the name of the computer containing the shared printer that you want to access.
  3. Right-click the shared printer that you want to access, and then click Connect. Alternately, you can double-click on Printers to see just the list of shared printers, and then right-click the shared printer that you want to access, and then click Connect.
After you have connected to the shared printer, you will be able to print to this shared printer as long as the printer and the computer sharing the printer are turned on.
please note that in network the computer that has the network printer if it is running XP may take as long as 15minutes to be recognized.
Apr 09, 2008 | Samsung ML 1610 Laser Printer
3 com hub tp4 home network setup failure
There are several possible problems here, and more information is needed to identify which one is causing trouble. First, are you using a high speed dsl or cable internet connection? ...or is your Internet connection a dial-up phone line? This will have a significant effect on how your cables should be connected between the hub and the computers. Windows typically defaults to a 169... address when it is not properly connected to a shared network connection.
Jan 08, 2008 | 3Com HomeConnect (3C19261) 5x10/100 Mbps...
HP DeskJet 9800d InkJet Printer Logo
16 people viewed this question
Ben Johnson
