Whirlpool Duet GHW9150P Front Load Washer
Problem for Whirlpool Duet GHW9150P Front Load Washer
F21, won't drain, unplugged, door still won't
By mrstlmiller on Nov 02, 2009
F21, won't drain, unplugged, door still won't open, won't run, full of cloths & water, tried every thing the call center & manual said. Don't have a service call until tomorrow afternoon.
Comments:
Nov 02, 2009
- Can I do this if it is a new washer and still under warranty? I have folks telling me I'll void the warranty if I do it myself. I'm just worried about the cloths, hope they don't rot before service tomorrow (Tues.) afternoon. They've been in water since Friday evening!
Best Solution
posted on Nov 02, 2009
Very Helpful)
jsrock516
Rank: Guru  Whirlpool Washers & Dryers  Expert
Rating: 96%, 6767 votes
This is a repair that you can perform yourself. "F21" is a Long Drain error code. This indicates that you have an obstruction somewhere in the drainage system. In most cases, this means you probably have a clog in the drain pump. The following link explains:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
You may have something getting caught in the pump impeller and slowing it down. Or, you may have something clogging the drain lines. Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris can commonly clog in this area as well causing the drain cycle to fail.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
NOTE: The "SUDS" error can also commonly occur with the F21 error code as this is can be generated when air is sensed in the drainage system.
If the door won't open it could be jammed due to the program being interrupted. There is a manual release you can use to retrieve anything left inside the drum. The following link explains:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
In most cases, simply resetting the door in this manner will restore normal operation.
If you have any questions, please let me know. I hope this helps you.
Comments:
Nov 02, 2009
- If the washer is still under warranty, this may void it. Your clothes will be fine if its only going to be one day before the repairman arrives.
Nov 02, 2009
- NOTE: If you want to drain the tub to avoid the water from souring, you can use a wet/dry shop vac and pull a vacuum on the drain line. This will remove the water from the tub and will not require you to open the unit in any way. This may also dislodge anything that may be caught in the drain line. If the washer still displays the error code after using this method, either the clog is in the pump, or the pump has failed.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
Not Rated)
salde386
Rank: Guru  Washers & Dryers  Expert
Rating: 94%, 43 votes
take the bottom panel off,you have to clean out the pump,probably coins in there,you'll see a round cap on right hand side,use plyers and twist to the left,if you have a wet and dry vac use this and put towels down,twist the cap enough so that you can vac the water as it comes out,after draining water twist the cap and take it out,clean it and feel drain hose,you might have to take hose off where it connects onto pump if you feel junk in hose,don't sqwease it hard you don't want to pop a hole in hose if something like a bobby pin is in there,should be all set
Comments:
Nov 15, 2009
- also you might have to change out the pump,coins or junk that gets stuck in there can kill it
Was this helpful?
Yes
No
Popular Solutions for Whirlpool Duet GHW9150P Front
Questions and Unsolved Problems for Whirlpool Duet GHW9150P Front
Do you recommend Whirlpool Duet GHW9150P Front Load Washer?
Answer
Answer
How do I turn off the "control lock" on my Maytag Epic front loader...my child was playing... (More)
Answer
washer stopped working yet makes sounds like it is trying. the drum is not moving and water is in... (More)
Answer
My duet is not spinning fast even though it is on the highest setting
Answer
my washer faults at the end of the final cycles and i have to reset a couple of times for it to... (More)
Answer
my washer gives me an error code F-2 and will not start cycle water starts the nothing
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Whirlpool Duet GHW9150P Front...:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14851
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
