Question about Epson Stylus 680 InkJet Color Printer
Poor print quality
When doing a nozel check print, the short horizontal lines which make up the sloping lines are misaligned in the vertical axis and I'm getting fuzzy prints. This only affects the black ink, colour is fine.
I've run through the cleaning protocols and changed the cartridge...any suggestions.
  • Epson Master
  • 1,879 Answers
Im sure your familiar doing the head cleaning from the computer / driver at least 3x consecutively
and still the issue persists, hardware problem
printer needs service / this might come handy : http://www.epson.com/loyalty
Posted on Jan 03, 2008
Ir 400 machine ccd in the copy horizontal lines problem what is the solution
Cleaning the ink jets of the print head, adjusting the vertical alignment and/or replacing the ink cartridges may improve print quality. You will first need to identify which cartridge(s) need to be cleaned by printing a Print Quality Check Sheet.
Nov 12, 2017 | Cameras
Print problem sir in 2420L
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing.
Happy with us Dial Epson Printer tech support phone number 1-877-778-896 for technical support of customer executive regarding with the Epson printer, if your printer is not connected with your PC & Laptops, Don't worry, dial our Tollfree 1-877-778-8.9.6.9 and get better and feasible solution of your issues within a time in the USA.If you want more information regarding with Epson n printer visit us:http://printertechnicalhelp.com/epson-printer-technicalhelp.html
Nov 25, 2016 | Office Equipment & Supplies
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
Draw a line graph of water temperature vs time
On the x-axis (horizontal axis) represent the time variable. On the y-axis (vertical axis) represent the temperature.
Mar 03, 2014 | Texas Instruments TI-84 Plus Calculator
Can i ask how to answer this?2x-4y-9=o
That is an equation describing a straight line. The "slope-intercept" form of a line is
y = mx + b
where m is the slope (change in y-value / change in x-value)
and b is the y-intercept (the point where the line crosses the y-axis when x=0)
Positive slope means the line is rising and negative slope means it's falling.
You can rewrite the original equation 2x - 4y -9 = 0 in slope-intercept form:
y = (1/2)x - (9/4)
So you know the slope is positive 1/2 (line rises 1 y-unit for each 2 x-unit change) and crosses the y-axis at -9/4. With this information you can graph the line.
Jul 12, 2011 | Sewing Machines
My MP600 printer prints horizontal stripes on glossy photo paper. Also, a single line of black dots prints vertically. I have deep cleaned the nozzle and realigned the printing. The wide black cartridge...
First your white horizontal lines are due to you not printing in the best quality. Go into the printing preferences and change the quality to best/quality.
The dots printed vertically are possibly due to ink getting onto the star wheels on the doc exit rollers. Also its possible that the printing media is a bit on the thin side and may need to be supported when exiting the machine.
Those should solve your problem. A new printhead wont make any difference.
Good luck
Jul 10, 2011 | Canon PIXMA MP600 all-In-One InkJet...
Poor print quality, but only on certain lines
Pull out the cartridges. Wet a q-tip with alcohol and clean the foil contacts that are in the spaces that the cartridges just occupied. Use a flashlight to better see what you are doing. See if that helps.
And what kind of lines are you getting on the printout? Vertical?Horizontal? Those could be ink that is on the feed rollers.
Jul 17, 2010 | HP Officejet 6310 All-In-One InkJet...
Horzontal white lines cut through print and picture copies. When doing head allignment the horozontal bars all have a white gap, 1 through 7. Epson Stylus CX5400
You don't need to do head alignment, because it is for vertical banding in printout. Vertical banding can be minimized by disabling high speed option without doing head alignment. If your printout have horizontal white lines, do check nozzle and head cleaning, or you can minimize white lines by printing in best quality (photo).
Oct 21, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Vertical and horizontal lines when printing photos - HP Photosmar
it sounds as if you may have the picture quality set to draft, its worth a check, especially if printing is ok. Does it print colour writing well too or just black, one of the colour inks may have a block or be low, go into printer settings menu and check what print quality its set for.
Apr 25, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Verticlel lines appear when colorprinting photos
There may be multiple reasons why your pictures and printed pages have unexpected vertical or horizontal lines. To resolve this problem,
http://www.kodak.com/global/en/service/repair/troubleshooting/aio-troubleshooting.jhtml?pq-path=10355
Within the Link, select Print quality, then Unexpected vertical or horizontal lines (banding).
Nov 11, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Epson Stylus 680 InkJet Color Printer Logo
98 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
