Question about Biostar M7NCD ULTRA Motherboard
Biostar motherboard i was updating my bios and after that it would not read the drives-so i installed my xp on a older computer-the bios on the old compaq is setup that you can only install 14gbyte hd- i tried to install the 80 gbyte hd that had all my info and programs on but it will only would read 14 gbyte which will not work-should i buy a new motherboard to install the 80 gbyte hd on- is this normal- thanks bill
  • 146 Answers
Re: biostar motherboard
I am not certain how "old" these systems are but it sounds like upgrading is not necessarily going to be smooth. has a barebones system you can install your hard drive in and be up and running. Here's the link:
Posted on Jan 03, 2008
0 characters
3 Points
I have a Motherboard MSI 865PE Neo3 MS-6728 ver3.0. You can install Win XP normally but is will never boot any Windows 7 CD installer with boot error "CDBOOT: Cannot boot from CD - Code:5". I...
be sure if you computer and the installer is the same as 32 or 64 bit.. check your computer and your installer.... be sure you have updated version of your motherboard..
Jun 30, 2011 | MSI 865PE Neo3-FS Motherboard
I recently updated my bios of mother board g31-m7te,how to roll back to old bios
Why do you think that you need to roll-back?
Each BIOS-update typically is 95% the "same" as the previous, so it's strange that the "new" 5% could be causing a problem.
What has stopped working?
Did you use the BIOS-update utility to create a 'backup' of the old BIOS? If so, re-flash with that code.
If not, look at the web-site from where you got the updated BIOS;
perhaps, it also offers back-level versions of the BIOS.
Re-flash your BIOS, with the older code.
Oct 05, 2010 | Biostar G31-M7 TE Motherboard
I wish to dual boot on a U8668-D motherboard P4M266A-8235 Pentium 4 2.8 mhz I would like to update the problem as I want to run Win 98 & Win XP on the same computer. I have been trying to download the...
flashing or updating the bios is a critical step, make sure there's an actual and valid need to do this as if something goes wrong while you do it your motherboard will be dead afterwards.
now.. instructions on how to update your bios can be found here
for dual boot installation make sure you create 2 partions, install 98 first in one and xp, second, in the other partition
for more info on dual-booting check this
good luck!
Mar 14, 2010 | Biostar U8668 (U8668DV7) Motherboard
Original motherboard sound drivers from MB disk don,t work.
Here is a link to the driver page for your board.
updates and see if this is
You could try downloading the driver from the site..Maybe there is a problem with the one on the disk. Also check the BIOS updates and see if this is a known issue. They may have a BIOS update to fix this issue. Before installing the driver/software I would remove the current audio software and remove the audio from the device manager and then re-boot the computer. Then install the downloaded software and see if that works.
Sep 08, 2009 | Biostar TA790GX Motherboard
Problem installation on Windows XP
Three things
1) Do you have enough memory at lest 1Gb
2) Is it a full genuine Windows disk. Some disks out there are a mixture of different things and some cannot find hard drive
3) Try another setup disc and see if it works
Sometimes the disk has a read fault
One last thing to try is Reset BIOS to default
Oct 12, 2008 | Biostar M7VIG-400 (M7VIG 400-COMBO4)...
CPU model not recognized correctly
Any multiplier settings in bios? try using something like CPUID in your OS to see if it clocks faster then what bios tells you?
Feb 26, 2008 | Biostar M7VIG-400 (M7VIG 400-COMBO4)...
Cpu install
If you go in to the bios you should be able to change the multyplier from x6 to x16.
Failing that try loading optimized default in the bios. :)
Dec 20, 2007 | Intel Motherboard
Biostar M7NCD ULTRA Motherboard Logo
99 people viewed this question
Top Biostar Motherboards Experts
Brian Sullivan
Brian Sullivan
Mark Taylor
Mark Taylor
Are you a Biostar Motherboard Expert? Answer questions, earn points and help others
