Home | Canon | PIXMA MX700 All-In-One InkJet Printer | What does 6A60 error mes...
Canon PIXMA MX700 All-In-One InkJet Printer
Problem for Canon PIXMA MX700 All-In-One InkJet Printer
What does 6A60 error message indicate and how do I
By yancie on Nov 02, 2009
What does 6A60 error message indicate and how do I resolve on my Canon MX700 all in one machine.
Comments:
Nov 02, 2009
- Error 6A80 on Canon MX700 all in one. I have checked and removed all traces of paper jam. I have disconnected both the power and ethernet cables and waited over night to no avail. Is this error correctable in a home setting or is it ready for servicing? In my case technical servicing is 100 miles away.
Nov 02, 2009
- Where is the purge unit located? I can see no bits of paper anywhere either from the back of the machine nor from the front.
Solution #1
posted on Nov 02, 2009
Somewhat Helpful)
ZJLimited
Rank: Guru
Rating: 93%, 423 votes
Canon MX700 Office All-In-One InkJet Printer : Error Code 6A80
There is an error showing "Error Code 6A80" and tells me to turn it off then on. It's still showing the error message?
Solution:
The error code means that a part of paper was ripped inside after a paper jam issue, or there is a foreign object stuck inside the printer.
If the error still shows after checking inside the unit for any obstruction or objects, the unit requires service.
Hope helped.
Comments:
Nov 02, 2009
- If the device is not functioning properly or to clear memory, reset it:
1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
2. Wait approximately ten seconds and then press the <ON/OFF> button again.
3. Wait until the device has completed its cycling process before submitting another job request.
Good luck.
Nov 02, 2009
- Also check the sheet feeder and purge unit; 6A80 error is an APP position error. It means that an error has occured when the motor was running during the purging operation on start up, sometimes pieces of paper stuck in purge unit.
Nov 02, 2009
- For lokk the purge unit, you need using flashlight in the right side on printer. Check the sheet feeder. If this not help your printer need service.
Nov 02, 2009
- Usualy is the purge unit that clean up the print head, and it's located inside on the right side (printhead parking place).
Take a torch, lift up the scanner unit, with the unit ON, wait for the print head to come in the middle, move it to left to make more room, and check the right side, inside the unit.
Was this helpful?
Yes
No
Solution #2
Somewhat Helpful)
firesnake09
Rank: Wiz
Rating: 84%, 364 votes
6A60 error is an APP (Application Printer) position error. It means that an error has occurred when the motor was running during the purging operation on start up.Check the sheet feeder and purge unit.Sometimes pieces of paper stuck in purge unit.
Thank you!
Was this helpful?
Yes
No
Popular Solutions for Canon PIXMA MX700 All-In-One
Questions and Unsolved Problems for Canon PIXMA MX700 All-In-One
Do you recommend Canon PIXMA MX700 All-In-One InkJet Printer?
Answer
Answer
Model MX700 - scanner operates to send image to comuter but will not operate to make copies from... (More)
Answer
The printing and copying functions of my Pixma MX700 work fine but the scanning function doesn't... (More)
Answer
paper not feeding, used to feed more than one page, now not feeding at all. Want to open up and... (More)
Answer
My Canon Pixma Printer MX700 is near new and the screen is showing Error Code 6A80...and the alarm... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon PIXMA MX700 All-In-One...:
Top Printer Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
