Printers
Problem for Printers
Generic problem for all Printers
I have a Roland Versacamm
By nora228 on Nov 02, 2009
I have a Roland Versacamm model that is printing full solvent inks. THis morning it has started dropping out the yellow ink completely. I have fitted a new cartridge, a new damper and cleaned the printer. But yellow is still not working. What do you suggest?
Comments:
Nov 02, 2009
- This is not a paper printer, this is a wide format inkjet printer. If there was a nozzle blocked I would be geting some Yellow print, but not a full print. I am not getting any yellow to print at all. There is a complete drop out of the Yellow print.
Nov 02, 2009
- This is not a paper printer, it is a wide format Inkjet printer. I have cleaned the print heads fully. There is NO Yellow ink printing.
Nov 03, 2009
- No 'computer shop' can fix a wide format ink jet printer. The yellow is 'dropping out' of the print, .ie it is not printing. It is not leaking on the print either.
Nov 03, 2009
- There is no hardware malfunction, the colour merely dropped out. there should be a relatively simple solution.
Nov 03, 2009
- Thank you. The pump is working fine - I have cleaned the heads & changed the damper. Ink lines are flusing through ok on the cleaning cycle, so they are not blocked.
Nov 03, 2009
- No white lines on pump.
Nov 03, 2009
- Pump is working fine,and I changed the damper. Ink is flushing through on cleaning cycle so lines are not blocked.
Nov 04, 2009
- There are no error codes, the machine thinks it is printing yellow. The cleaning cycle pulls all inks through the lines & it IS pulling through the yellow - therefore no ink blockage. After a powerful cleaning cycle the yellow prints a little & then rapidly drops out again.
Nov 04, 2009
Nov 04, 2009
- I have tried turning it on and off. This is not a standard printer - no reset switch.
Nov 04, 2009
- It can tell me how much ink is left in the cartridge, so it must be able to read it.
Solution #1
posted on Nov 04, 2009
Somewhat Helpful)
drifterK
Rank: Guru  Computer Hardware  Expert
Rating: 86%, 359 votes
hold down the on/reset button a few seconds ....on some printers this will reset it and it might just work ...
Comments:
Nov 04, 2009
- I understood that ..its something like an industrial printer for newspapers and so ...but it has to have something like this ...the issue is that it doesn't see the ink cartrige anymore ...cause of that lick ...try to clean the sensors ...around it ...I believe its located somewhere at the bottom of the cartridge ...anyway ..ask for another opinion ...someone might really know what to do..
Was this helpful?
Yes
No
Solution #2
posted on Nov 03, 2009
Somewhat Helpful)
jjcom453
Rating: 88%, 209 votes
I have read through the comments you have posted. If the lines are not blocked and the nozzle is not clogged then you have to have either a program fault or a hardware fault. Double check your contacts on the cartridge to make sure they are making contact. If possible clean the contacts on the printer, you should be able to carefully use an eraser to clean them. If these are clean try printing from another program to see if the printer will print Yellow. If the other program works then you need to re-install the program you have having problems with. It may be a good Idea to remove and re-install the printer drivers to the computer as well. Hope this helps.
Was this helpful?
Yes
No
Solution #3
Somewhat Helpful)
micromatikal
Rank: Wiz  Computer Hardware  Expert
Rating: 84%, 232 votes
Unfortunately it sounds like the wide format printer you have will need some hardware replacement, it sounds like some part of the ink control has malfunctioned =(. Very difficult to say what you have going on, you sadly will have to call Roland to have them diagnose it. Their number is:
(800) 542-2307
Was this helpful?
Yes
No
Solution #4
Somewhat Helpful)
geo_jonas
Rating: 80%, 336 votes
Hello, regarding on your problem i suggest that if you can find a computer shop in your place or contact the supplier of your printer then let them examine and fix the problem. In that way you are assured that they can fix it because they have complete tools and equipment for repairing and fixing the printer's problem. Also to prevent any additional damage from your printer cause if the ink continues in dropping out the yellow ink it might possibly damage the printer board and eventually you have to buy new one. So the best and simple suggestion please follow the instructions above.
Thanks
Was this helpful?
Yes
No
Solution #5
posted on Nov 02, 2009
Somewhat Helpful)
blueextc3221
Rating: 90%, 1435 votes
Re-clean. There may be a nozzle clogged.
Use Isopropyl alcohol and a cotton swab.
Also clean the contacts with an eraser - run test pages to verify proper ink usage.
Thanks
Was this helpful?
Yes
No
Solution #6
Somewhat Helpful)
parrotheadpc
Rating: 89%, 554 votes
I am not a printer expert but I believe this printer has a pump and ink supply lines? Is it possible that either the supply or the drain lines may have a plug? I would disconnect the lines and check them for stoppage, then reconnect and check the dampers, supply, drain lines and dampers seem to be the 2 biggest problem areas.
Replaced the damper and cap top. Check the line that runs out of the pump to the drain bottle for plugs. What color are the lines on your pump? The old pumps had white lines and were a problem.
Comments:
Nov 03, 2009
- Is this machine giving any kind of a trouble code? that would help a great deal if there was a self diagnostic done to find out where the problem might be. Is it possible to draw any yellow ink from the supply cartridge to make sure it is able to flow out of the cartridge itself?
Was this helpful?
Yes
No
Solution #7
Very Helpful)
akyles
Rating: 86%, 86 votes
Sorry to hear that you are having problems with you VersaCAMM printer.
First, be sure to locate where the ink is leaking. Usually, when the head printer goes bad, it leaks thru the head. However, this is not the only issue that it may cause the problem.
I'm not sure what model number do you have, so I'm providing a generic solution.
* Check for cracked manifold stems, if cracked, replace cap tops, stems and damper. Better if you replace all.
* Replaced yellow damper/Syringed ink to create vacuum.
If everything looks fine at this point but still having problems, then you need to go technical:
* Power off the equipment and look for blown fuses. If any, replace it. Keep a few fuses handy in case it blew again.
* If fuse were replaced but it breaks again, there is a short circuit in the board. The board (an expensive one) may need to be replaced.
* At this point, a technician with experience in component level repair may need to check this printer.
Hope this helps, Good luck.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Printers
Questions and Unsolved Problems for Printers
Answer
MP 620 printer is it a good buy
Answer
konika minolta 1600 magicolor
Answer
pictures are not as clear as they used to be
Answer
Just received a 2nd hand Canon MP970 and the idiot didn't lock the scanner before dispatch - now it... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Printers:
Top Printer Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
