Question about Proton MM2701VT 27" TV
36" Mitsubishi tv rolls
Unable to find an adjustment on the back of the tv to stop the tv from rolling
  • Vicki1970 Jan 04, 2008
    Model Number CS 35301
    Serial NO. 541520
    April 1994
  • 1,694 Answers
Please provide Model # and mo / yr off back of set and I can help you...................T.
Posted on Jan 03, 2008
  • Vista Electronics Jan 04, 2008
    Thank You for the info !
    Solution is.....remove PIP module ( defective)
    On VP connector bottom of chassis...use 22mf NP 50v caps
    to connect pin 5 to 11 and pin 7 to 9.....that will pass video
    to full screen,but PIP box will not work.......this repair is called
    a PIP by-pass...........a very common Mits. repair..............T.
I have a 1999 Mitsubishi Projection TV and the vertical hold wont adjust. How do I reset it.
Put it back to the mid point of it's adjustment range.
If the V hold won't stop the picture rolling at some point in its adjustment range then the circuit that it affects has drifted out of tolerance. The defective parts in that circuit need to be replaced.
Sep 10, 2014 | Mitsubishi Televison & Video
I have a Mitsubishi VS 50605 projection tv that needs to have the vertical hold reset. How do I reset it.
If the V hold won't stop the picture rolling at some point in its adjustment range then the circuit that it affects has drifted out of tolerance. The defective parts in that circuit need to be replaced..
Sep 10, 2014 | Mitsubishi WD Televison & Video
Rolling green horizontal bar from top to bottom,then bottom to top and so on. sometimes rolling fast,sometimes slow and sometimes the green bar stops in the middle of the screen.every once in a while the...
This TV needs a service adjustment done. Looks like a vertical or horizontal IC is failing. I'd go ahead, and shut off until services adjustment is made. Have you unplugged for a few minutes and plugged back in? However, I'd have a service tech look at it.
Oct 25, 2009 | Mitsubishi WS-48513 48" Rear Projection...
Thick black line rolling up the recorded video of the TV
That is the camera not being in sync with the refresh rate of the TV. With consumer gear, there is really not much you can do about it.
Sep 08, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Screen rolls maybe vertical sync
May 26, 2009 | Mitsubishi VS-45605 50" Rear Projection...
Picture rolling when I first turn on my tv
A rolling picture or loss of vertical sync can be caused by several components including a bad signal board or jack panel assy. You will not be able to resolve this yourself. contact a Mitsubishi authorized service center.
Feb 14, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi TV picture rolling
Look on the back and see if you have an adjuster.(It should say
H-HOLD) Just turn it very slowly until the picture stops rolling,You can do this by watching the tv screen in a mirror.
Please rate this solution.
Jan 16, 2009 | Hotpoint HSS25GFP Side by Side...
Rolling screen
my screen on my mitsubishi won't stop rolling
Aug 22, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Rear project TV problem
yes it can be fixed depending on your model number if its the VS50605 they have a kit to repair the PIP module which controls vertical sync (Rolling) or you can bypass the module to correct it but you would lose the PIP function. Let me know if you need more info.
Apr 17, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Picture is Rolling..stops after some warm-up
I have seen this many times. There is a 9 volt regulator on the small signal board that causes this. The regulator goes bad and the 9 volts starts dropping, especially at start-up when the regulator is cold. If the voltage is below 8 volts then the picture gets dark and the vertical becomes unstable, with the picture squeezing down and/or rolling. As the regulator warms up the voltage starts rising back towards 9 volts and the symptoms start clearing up. There are 3 regulators in a row on the board and the regulator in the middle is always the bad one. Replacing that regulator should cure your problems but it should be replaced by someone experienced in servicing Mitsubishi projection TV's because pulling the chassis out is quite tricky.
Aug 05, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Proton MM2701VT 27" TV Logo
71 people viewed this question
Top Proton Televison & Video Experts
matt martin
matt martin
Are you a Proton Televison and Video Expert? Answer questions, earn points and help others
