Question about Standard (CRT) Televisions
TV picture too wide
Picture appears to be twice as wide as the screen. I have tried adjusting picture size i.e 4:3, 16:9 etc but no joy. I have even tried resetting the TV but picture remains the same.
3 Suggested Answers
  • 206 Answers
SOURCE: Tv picture needs adjusting
Majority of problems in tv sets is not a simple adjustment but insted a componet failure of some sort. So getting in to the service menu or adjusting pots on the main board usaly gives you two problems to repair
Posted on Jan 30, 2008
SOURCE: 20MT133S picture too wide for tube
There is a section in menu but i can't think of which one it is at the moment. I would suggest playing with your menu and you will find it.
Posted on Aug 14, 2008
  • 603 Answers
SOURCE: Sony 42inch tv picture has reduced itself to size
There should a selection for the size picture your viewing. There is most likely a zoom selection as well.
Posted on Dec 28, 2009
0 characters
1 Points
How do I adjust the screen size on a Hisense tv
You have enter its service mode option to adjust the picture height. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Nov 29, 2014 | Hisense TC24FS2H TV
On Sony 36 iinch Trinitron TV, when I go to HDTV channels the picture size changes to widescreen. How do I adjust back to full screen on HD? I tried the "no zoom" button but that doesn't work. Cannot...
Please note that all HDTV channels project wide screen pictures. You can still go to settings and then picture mode and change the format to 4:3/full mode.
Aug 28, 2010 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Picture too large for screen
It appears that on this television you can only adjust the picture size when you are using the twin picture feature. You must adjust the picture size with your other remote control. Since I do not know whether you are connected to a cable box or a satellite tv box or a blu ray player or a DVD player I cannot be very specific. On your other remote control you should had an hd zoom button, aspect, format, ratio, #, or etc. Those buttons change the picture size. The other factor determining picture size is the resolution the equipment connected to your tv is set to. This tv supports 1080i but you should also try setting the connected equipment to 720p or 480p or 480i. Also the connected equipment may be connected to your tv in two places so make sure you are on the correct selection using the tv video button on the Sony remote.
May 06, 2010 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Sony 42inch tv picture has reduced itself to size of regulaur tv instead of wide screen. How can this be adjusted ?
Dec 28, 2009 | Standard (CRT) Televisions
Picture is too wide for the screen can`t see all info on program guide on left side
you are viewing in16:9 ratio (widescreen) and your tv is 4:3 you need to change your picture settings in the tv menu
Aug 29, 2008 | Sylvania SRT2232S 32" TV
Picture too big for screen?
There is a service menu that controls such things as picture size etc. and that's likely where adjustments have to be made.
Unfortunately I'm not sure how to get into it. That information should be here somewhere, search for your tv brand and "service menu".
Jun 30, 2008 | RCA 20F410T 20" TV
Size of the picture decreased
If this only happens with your cable or satellite box this may be an adjustment in your box. So you may need to contact them and find out how to adjust the picture size. This tv may have a wide mode setting on the tv remote. Pushing this button may select full,wide,wide zoom or normal size. On many occasions the tv stations control the picture size. Good Luck
Jan 23, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Zoom in and zoom out
Try looking in the menu under PICTURE. see if there is picture size adjustment for picture size eg 16 x 9 4 x 3 normal wide.
Nov 10, 2007 | Bush 2871NTX 28" TV
Standard (CRT) Televisions Logo
120 people viewed this question
Top Standard (CRT) Televisions Experts
matt martin
matt martin
Are you a Standard (CRT) Television Expert? Answer questions, earn points and help others
