Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Images go suddenly darker
Sharp aquos  pulses dark, the image is darker, than brighter, than darker ....
    Sniper:
  • 53 Answers
Turn off the the OPC feature in the Menu. If that doesnt help, what youre seeing is most likely the Advanced Dynamic Contrast going to work. In layman's terms, it automatically adjusts the contrast depending on the video signal it is receiving. If you want to disable this, change the AV settings to "User" (button underneath the bottom door on the sharp remote)
Posted on Mar 14, 2008
There`s a problem with the image.is dark on the left side of the screen,image it`s ok,but dark
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Nov 29, 2014 | Sharp AQUOS 70" 857 Series LED HDTV -...
Luminous
Please provide the model and make details
Apr 08, 2008 | Sharp Aquos LC-PD50U 50 in. Plasma...
Dark lines on Sharp Aquos 42" screen.
if the unit is stll under warrenty it would be best to take it back, it does sound like that it is the lcd that is faulty, or contact Sharp to see if the can repair it for you
Thanks
Oct 19, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Picture pulses
replace the flote.
any repairman will know wat this is.
part cost is from $56 to $93.
check around
partsstore dot com keeps a good parts stock for tompson or rca.
hope this helps
regards,
daniel.
Jan 13, 2009 | RCA P60921 60" Rear Projection Television
Photos printing too dark
try editing the photo.. more brightness, contrast etc etc.. see if it will also print brighter... if it still prints the same i guess its time to throw the printer back to epson
Dec 26, 2008 | Office Equipment & Supplies
Pictures appear to be darker than original in print outs.
You can make several adjustments to improve your images such as lightening dark areas, changing the exposure, sharpening blurred edges, and changing the brightness and contrast.
  • Exposure adjusts the overall intensity of light in an image.
  • Adaptive Lighting improves only the dark areas in an image without affecting the bright areas.
  • Brightness adjusts the amount of light in colors ranging from light to dark.
  • Contrast adjusts the difference in brightness between light and dark areas of an image.
  • Sharpness helps define edges and the smoothness of texture in an image. Use this tool to make a blurred image appear more focused.
Adjusting the image Follow the steps below to make adjustments:
  1. Click the View tab and select the image you want to edit by either clicking the image, or by clicking the small box at the bottom left corner of the image. Figure 1: Select the image c00603524.gif
  2. Click the Edit tab and then click the Advanced tab.
  3. On the Advanced tools tab, click Adjust Image .
  4. Select an adjustment from the list on the left. Figure 2: Adjusting the brightness c00603525.gif
    • The Exposure adjustment is automatically applied when the Adjust Image tool opens. Eight variations of the image are displayed on the left. The current image is displayed in the center. Each image represents a different level of adjustment. When you move the pointer over any of the images on the left, a large version of the image is displayed. Use Preferences to turn this large image preview on or off and to set the timing for the display.
    • If you want to use a different adjustment tool, select Adaptive Lighting , Brightness , Contrast , or Sharpness from the list.
  5. Select one of the images on the left.
  6. Do one of the following:
    • Click Accept to accept all changes and exit from the Color Toolkit.
    • Click Cancel to discard all changes and exit from the Color Toolkit.
  7. If you have finished modifying the image, do one of the following to save your changes:
    • Click Save to overwrite the original image.
    • Click Save As to save the modified image with a different name.
Aug 25, 2008 | HP Photosmart D7160 InkJet Printer
Dark images too dark
Yes - go to mebu OPC off - and make sure active contrast is off in advanced settings
Feb 24, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Image adjustment functions
SHARPNESS - The function is to adjust sharpness of capturing images. CONTRAST - The function is to adjust contrast (distinction between light and dark) of capturing images. SATURATION - The function is to set color depth of capturing images. GRADATION - In this function, you can select the brightness of an entire image. It is suitable when you want to add a brighter effect to a bright object (Hi Key) and a darker effect to a dark object (Low Key).
Sep 04, 2005 | Olympus EVOLT E-300 Digital Camera
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
368 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
