Question about Sony Cyber-Shot DSC-T5 Digital Camera
Lcd problem i cna barely see the picture in the LCD, i can still take picture but the scree is not bright enough i set teh setting LCd as bright it was fine but not anymore, any idea? thank you i appreciate yoru help.
  • 1 more comment
  • osnap Feb 22, 2008
    LCD backlight says it is in bright but there is no backlight at all.
  • Anonymous Apr 10, 2008
    mine is quite the same. When I turn it on the numer E:91:01 blinking on the screen. I really need help cause camera is very expensive in here
  • annefe Jul 24, 2008
    Sony Cyber-Shot DSC-T5 LCD monitor is dark
Contact Ray @ enamor1216@aol.com He can help repair your camera.
He is great!
Have a nice day!
Posted on Jul 16, 2008
Google case no: 05-CV-1979-JAH-RBB
Posted on Mar 06, 2008
Why does it overheat?
does it overheat and closes or just superheats but works fine
from Lcd to lcd the lcd temp is high cause of the ccfl lamps that bright the panel enough so you can see the picture
If your tv set was led the temp would be greatly lower
Jun 11, 2014 | LG 37LD450 37 in. TV
Lcd has no picture lcd working normally but the picture does not show
Go into camera menu setting, check LCD bright settings make sure the setting has not gone too low.
Jun 04, 2010 | Sony DCR-HC19E Mini DV Digital Camcorder
Dark screen when I turn on the camera and take pictures.
It looks like the LCD backlight malfunction. Check the backlight voltage, if you have the voltage there, you need to replace the LCD unit, otherwise the main board is defective.
Aug 03, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
Outdoor photos are all over exposed and white. Video works fine.
set ur screen first .click one image 1st load on ur pc. see the screen and pc screen then set ur screen brightness and contrast of ur camera
Jun 17, 2009 | Mitsuba DV505 Digital Camera
White screen on my camera and can take picture picture is black colour
hi
i think the LCD has been set to a very high brightness set the LCD brihtnes lower from the settings..
better more is to reset the camera to the default settings this would set the aperture, shutter, Exposure, LCD brightness and other settings to defaults and this would save from any unwanted changes than required
cheers
pls rate if it was any help
May 17, 2009 | Samsung Digimax L60 Digital Camera
No picture
LCD TV TroubleshootingThe defective LCD TV may have the following common symptoms:
Symptom: No picture on screen but LCD TV still has sound.
Solutions: The problem is cause by defective inverter. Replacing ivnerter will solve hte problem. Symptom: Screen flash on and off between 1/2 to a few seconds, but power indicate light stays on and TV still has sound.
Solutions: The problem is cause by defective inverter. Symptom: Blue Screen but no picture
Solutions: The problem is cause by defective Main Board(AD Board). In some cases, this problem may cause by the defective Screen Controller board. Thsi board is mounting on teh back of LCD TV Scree. Symptom: Power light stays on but no display and sound
Solutions: The problem is cause by defective Main Board(AD Board) or Power supply board. Symptom: No Power or Power indicate light does not lits
Solutions: The problem could cause either by defective Power supply board or defective Main Board(AD Board). Symptom: Screen is half dim and half bright
Solutions: The problem is cause by defective LCD Panel.It needs to be replace.
This is a power supply problem. Try to check the fuses ,fusable resistor ,capacitor and transistor in power supply board.
Hope it may help you;
Regards,
VOTIT
Oct 01, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Picture washed out, can't get it right
Sep 21, 2008 | Akai LCT2715 27 in. LCD Television
I just bought the LG 47LC7DF tv. I would like your opinion on how to set up the tv with the best setting as far as contrast, color and brightness etc
As a rule of thumb, set your picture settings at there bare minimum which is comforttable to watch.
this is so that as the lcd ages, you can increase the settings to compensate - increasing the life of your lcd alot
Aug 05, 2008 | LG Televison & Video
Dark screen
if the picture is REALLY dark, like you can just barely see it in a lit room, then the backlight might not be lit. LCD TVshave backlight that shines through the LCD screen which allows you to see the picture.
If it's not the backlight then it would be the brightness/contrast settings that need to be adjusted. If the picture used to be normal and all of a sudden went dark, verify the backlight. Normally you can look through the slots on the top of the set and determine if the backlight is on. If you can see a bright light through any of the slots, the backlight is probably OK... go after the brightness/contrast settings.
Mar 25, 2008 | Vizio L37 Television
Sony Cyber-Shot DSC-T5 Digital Camera Logo
71 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
