Lexmark C935dn Laser Printer
Problem for Lexmark C935dn Laser Printer
Printer not printing over network
By broadcow on Nov 02, 2009
printer not printing over network
Lexmark C935 A3 printer. Some one stole the netwok cable when I replaced it the printer is no longer seen on the network. Cannot even ping it from the server. Have checked the TCP/IP settings
Solution #1
posted on Nov 02, 2009
Not Rated)
swoop611
Rank: Guru
Rating: 87%, 83 votes
Have you re-installed the printer drivers with the printer reconnected. Some tcp/ip printer drivers will lose their ip settings if the device is disconnected for a set number of reboots. Also, if the DHCP or NAT settings are altered, the device will vanish from the network. Try reinstalling the printer drivers with the printer connected and turned on and the device drivers should detect the printer again and reconnect to it. When the cable was removed, if it was simply pulled out, was any damage caused to the ports the printer was plugged into..? Network ports are fragile and the insertion or removal of a cable connector with just a little too much force can cause damage to the port. Carefully inspect the port both inside and where possible, outside including the electrical connections to the circuit board the port is fitted to.
Was this helpful?
Yes
No
Popular Solutions for Lexmark C935dn Laser Printer
Questions and Unsolved Problems for Lexmark C935dn Laser Printer
Do you recommend Lexmark C935dn Laser Printer?
Answer
Answer
change ink cartridge in samsung ml 2510
Answer
after replace of a 100k kit, how can i make the reset of this?
Answer
I have a lexmark C935, when I turn it on I get 925.03 service pc cartridge
Answer
HiI have a problem trying to print to a Lexmark C935 printer from a new iMac running Mac OS 10.5.6... (More)
Describe your Printers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
