Take the ethernet only and attach it to your router. If you are not
already using a router for your computer internet connection then if
your router has connection software that needs installing for network
setup for the router only you run the software on the computer after
connecting the router to the PC.
If you use the oruter for your PC connection already then do the following.
Connect the Ethernet from the PS3 to the router0
On the ps3 Go to settings
Go to network settings
Go to network connection, select enable
Go to Internet connection settings just below internet connection-
Push yes when it says you may be disconnected
Select wired or wireless
For wireless use scan or enter manually
Follow on screen instructions.
Once that is set up return to main menu and go to network near the right.
Here is a video instruction:
