Question about Mitsubishi WS-65807 65" Rear Projection Television
Tv does not stay on.
When we turn on the tv it will go off in 1-2 sec. The green light on the front that says timer will light for 1 sec or two. What could be wrong.
  • Mitsubishi Master
  • 8,617 Answers
Your most likely having a problem with your power supply. I would say check the capacitors for obvious signs of swelling and all fuses first. Next I would check your low voltage regulators.Have you tried pushing the menu and imput buttons together and holding them for 5 seconds to access the self diagnosis feature? If you cant initiate the self diagnosis feature its probaly the capacitors or Regulators.
Posted on Jan 03, 2008
SOURCE:
How do I fix my Jvc the screen won't power on. When I reset it the lights on the buttons light up...but shut off right away. It has power because the red light on the bottom left corner stays lit.
JVC LT-46AM73 LCD TV Won't Turn On - YouTube
? 3:28
https://www.youtube.com/watch?v=y5j3RGUe4gM
Feb 25, 2015 - Uploaded by Awesome Things
JVC LT-46AM73 LCD TV won't turn on after power outage. ...LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to ...
JVC wont turn on - JVC - Streaming Video & TVs
www.tomsguide.com/answers/id-1677424/jvc-wont-turn.html
May 15, 2013 - JVC lcd tv will act like its turning on then the green light after 2 seconds ... wont turn on Forum; SolvedAcer Laptop V4DA2, screen won't turn on.
My Jvc Av-32F476 Tv Won't Power On, The Green On Timer Light Stays ...
www.diyforums.net/my-jvc-av-32f476-tv-wont-power-on-the-green-on-...
Dec 8, 2013 - My jvc av-32F476 tv won't power on, the green on timer light stays on and m. ... On the remote control, look for the buttons PICTURE MODE and DISPLAY, with ... My Jvc Lt24dd52j Won't Turn On The Blue Light Is Flashing But ...
Nov 1, 2014
I Have A JVC LT-42TG30J, Randomly The Tv Has Decided It ...
Aug 29, 2012
I Have No Picture On My 47 Inch On My Jvc Big Screen Just A ...
May 23, 2012
My Dynex 42" Wont Turn On Power Led Is Lit Up But It Won't C ...
May 24, 2011
More results from www.diyforums.net
Jan 18, 2016 | JVC Televison & Video
Tonight my Sony Wega KDF-42WE655 screen went black and the audio stopped, the standby light (green) blinked on and off for about 30 sec. then the screen came back on and the green light blinked 5 sec or so...
Replace its lamp as existing lamp has been reached at end of its working hours life and need to replace to solve this issue. Please note lamp is not not broken or dead yet so you do not see lamp light on tv front.
Lamp replacement procedure is easy and written in user manual.
Please buy Sony original lamp for god picture in tv.
Thanks.
Dec 31, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Turn on tv...green lamp blinks several times.lights up but no picture...press any remote button timer in green blinks...tv turns off and goes to standby
The tv "LAMP"LED light indication flashes or stay lit?The tv projection lamp been in this tv like 1/2 or 2 years?Tv been on and used like 4 or 5 hours a day?Yes,than the tv projection lamp life are over.Require a new tv projection lamp.
Nov 17, 2010 | Samsung HLP4674W 46" Rear Projection HDTV
Got the tv stanby Working
The ribbon connector which goes from the FMT to the DM is disconnected or not seated properly thats the only thing that will cause the 4 4 error other than a broken ribbon socket
Nov 26, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62627 62" DLP TV
Try this:
1) turn on the TV
2) from the remote control press MENU 2,4,7,0 then ENTER
3) tv will state on screen that it is INITIALIZING
4) when done press the front reset button.
5) should be good to go!
Oct 26, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Flashing green light
Did you try this yet
SYSTEM RESET
If the TV will not respond to either the remote control
or the front panel controls and/or will not power Off,
press the SYSTEM RESET button with a pointed item
like the end point of a paperclip. The TV will turn Off
and the TIMER light will flash quickly for about one
minute. When the TIMER light stops flashing, you may
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
POWER/TIMER Indicator
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
Green light doesnot turn off on Mitsubish WS-65315
Just go to menu... then ..setup... then... timer ..and turn it off...... the blinking light goes away
Aug 29, 2008 | Mitsubishi WS-65315 65" Rear Projection...
Green power light will not stop flashing and tv will not turn on or off
You need to replace the 1000uf capacitors on the DM board thats the classic symptom of the DM caps being bad the light continues to blink repeatedly. If you need more info on the repair let me know.
May 15, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
Sep 22, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
Blinking Stand By/Timer LED
You can try this on the remote in standby mode, meaning tv plugged in but set off. Press Display,5,vol+,power on remote.Press each button within a 1 sec interv. Next the CRT display the item being adjusted. Press 1or4 on remote to select item. 3or6 to change the data. Press Muting then Enter to write into memory. Service Reset muting green enter red. Press 8 then enter on remote to initialize. turn set off to exit. wait least 10 sec. before turning back on.
Sep 10, 2007 | Sony KV-32V40 32" TV
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
65 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
