Kodak ESP 5 Printer
Problem for Kodak ESP 5 Printer
How do I clear a piece of paper jammed in my Kodak
By jandb_lamorn on Nov 02, 2009
How do I clear a piece of paper jammed in my Kodak ESP5 All in one printer
Solution #1
posted on Nov 06, 2009
Not Rated)
sajid_najmi
Rank: Wiz
Rating: 90%, 12 votes
1 Lift the output tray.
2 Open the paper trays and remove any paper.
3 Turn OFF your printer.
4 Wait 30 seconds, and then disconnect the following from the back of your printer: USB cable, Ethernet cable, Fax cable, AC power cord.
CAUTION: Do not use force when removing the paper from the printer.
5 Check inside the cleanout area for a paper jam. If necessary, remove any paper or debris.
6 If paper is not visible, check the printer for foreign objects, such as paper clips or staples. If necessary, carefully remove the foreign objects from your printer.
7 Open the printer access door.
8 Remove any foreign objects from the printhead access area, and then close the printer access door.
9 Connect the following to the back of your printer: USB cable, Ethernet cable, Fax cable, AC power cord.
10 Wait 30 seconds, and then turn ON the printer.
11 Squeeze and move the paper-width guide on the paper tray to the left.
12 Load the paper into the upper paper tray.
13 Squeeze and move the paper-width guide to the right until it touches the paper.
14 Close the paper tray.
Best of Luck
saj
Was this helpful?
Yes
No
Popular Solutions for Kodak ESP 5 Printer
Questions and Unsolved Problems for Kodak ESP 5 Printer
Do you recommend Kodak ESP 5 Printer?
Answer
Answer
cannot load software keeps freezing gets to 1 min to go then timer goes up to 16 mins then freezes... (More)
Answer
Kodak ESP 5 new cartridges color prints fine black will not print. Only have used Kodak replacement... (More)
Answer
The roller picks up 2 or more paper and is to thick to make it past metal tabs above roller in front... (More)
Answer
i recently replaced the ink cartridges and it is not printer as well as before
Answer
my laser printer has a black tint and got riped can i replace that
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Kodak ESP 5 Printer:
Top Printer Experts
Rank: Guru Guru
Solutions: 744
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
