Question about Motorola Mobility RAZR V3
Phone will not turn on
I have a brand new never used razr v3, the battery is fully charged,when I turn on the phone the key pad lights up but the screen remains blank
  • 4,102 Answers
Hi you say the key pad lights up but does it light up after a couple of minutes like when you press a key if this is the case and the keypad is functional and lights up when you press keypad if this is the case then the chances are that the screen hasnt been fitted properly.
did you purchase phone from shop or somewhere else if its new cant you exchange it the chances are if you didnt buy from reputible deler then the chances are they sold you a phone that should have never gone on sale.
As i used to work in a major mobile phone producer the phones are all tested before being shipped out.
The chances are the screen needs removing and replacing this is difficult to do yourself as the screws need to be undone in certain order and the same back together if not you can warp the board and destroy the phone completely.
if you want to try this yourself use a good search engine and look for the instructions on how to take phone apart but you need to earth yourslef out before doing this as the static in your bady can blow the chips on the board it is best left to a pro if you are unsure hope this is some help let me nkow what you want to do
Posted on Jan 03, 2008
Motorola Razor will not charge
turn the lights off in a room while the phone is on and see if you can see a light coming from the phone while it is closed and on.if you have a new battery did you let it fully charge before using.make sure the blue tooth is turned off.
May 13, 2010 | Motorola Mobility RAZR V3
Razr wont turn on
is it fully charge?.
May 08, 2009 | Motorola Mobility RAZR V3
Motorola RAzr V3 - screen went black but key pads lights up
replaced the flexcable on the phone to have it fix
Jun 29, 2008 | Motorola Mobility RAZR V3
RAZOR V3
it shows that you are having flex cable issues - common problem with the v3. you would have to bring it to a local repair shop or order a keypad flex and button flex cable to do yourself.
the parts are about $15-40 and a shop will charge about $25 to install
if all else fails contact me and we can help arrange it.
Feb 01, 2008 | Motorola Mobility RAZR V3
RAZOR V3
HAS IT BEEN WET? IF SO OPEN BATTERY DOOR AND REMOVE BATTERY THEN POUR RUBING ALCOHOL NOTE MUCH THEN VACUME NOW PLACE IT UNDER POWERFUL FAN OVER NITE.TRUST ME IT WORK'S...
Stupid phone
Contact Motorola directly. They are very good about warranty and will most likely overnight you a replacement.
Aug 09, 2007 | Motorola Mobility RAZR V3
Motorola Razr - Keypad Doesn't Work
My phone developed the same trouble............ Removed battery and SIM and blew dry air into anyhole I could find, put it back together and has worked ever since.
Thanks for the tip
Jun 25, 2007 | Motorola Mobility RAZR V3
Won't turn on after assembly
dear first check the the power volts are comming in ur on of key. if not comming check key pad strips. mostly it prob from key pad may be it is not good connected to board or damage during assembling. first unplug it and then re connect
Mar 23, 2007 | Motorola Mobility RAZR V3
Phone is dead wont take charge
You simply need a new battery. Razr batteries are notorious for loosing life and the entire problem is the chargers you are using. You MUST have one with an IC chip that tells it when to stop charging otherwise watch how long you are charging it. Also when you have a new battery let it fully charge and fully die twice before you start normal charging this helps a lot.
Feb 24, 2007 | Motorola Mobility RAZR V3
My phone not turn on
Check the mobile using another battery then it works normaly this is the problem due to battery.Recharge old battery using external charger
Feb 23, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
