Question about Mitsubishi HC100U Multimedia Projector
MITSUBISHI HC 100 PROJECTOR
PLUG IN WITH RCA CABLES TO PROJECTOR FROM DIRECT TV CONVERTER BOX ONLY RECIEVE SOUND NO PICTURE STATUS AS NO SIGNAL APPEARS
  • 563 Answers
Hi there
First try to bypass the box and put signal directly into the Projector from the source - i.e. DVD Player
If the signal still doesn't pick up , try using a different cable.
If the problem is solved , then your Converter Box is faulty.
If the problem still occurs then you might have a faulty Mainboard - as all the inputs on this Projector is situated directly on the Mainboard.
Hope this will help you !
Posted on Mar 27, 2008
Is this model, RCCA 20f512t, a digital model?
No,This tv is a CRT tv-(Tv Tube).All small tvs with CRTS design are analoge tvs.Tv must have a Converter box to convert for analoge tv to DTV signals to recieve for free broadcasting DTV tv stations signal.Must have pay signals like satalite Dishes,Cables or Telecoms signals.This tv can be use without a Converter box.
Jul 02, 2011 | RCA 20F512T 20" TV
Can i transmit a tv signal through my tv to the projector, ie- i want to watch live tv on the projector screen...can you help ?
yes you can, but not "through" your tv, unless your tv had component video outputs. you should run a component cable from your cable box directly to your projector, or do what i did and buy a multimedia reciever/surround sound system and run it to that then split it from that to your tv and your projector.
May 03, 2011 | NEC VT670 Multimedia Projector
Mitsubishi HC 5500. While playuing the picture disappears. No picture only sound, also status and power lights start blinking red and green
Red and Green bliking with no picture means a service problem. But you might try cleaning the filters first and being sure that nothing is blocking air flow through the projector. Red status solid means replace the lamp, but that doesn't seem to be the indication.
Feb 09, 2011 | Mitsubishi HC5500 LCD Projector
Cant find a signal to get channels on portable tv
Is this TV digital ready? if not you will need a converter box for the new digital signal that the government reguired this past summer. It should work if hooked to a cable box or sat reciever but without the converter box you can no longer recieve signals through the air.
Nov 26, 2010 | RCA 9V345T 9 in. Portable Television
Do i need a converter box for my rca true flat 27 in? if not how do i connect a digatal antenna i have lost my manual
Your TV will require a Digital Converter Box to recieve over the air Digital Television Signals. You will need to hook up the antenna to the converter box and then hook your converter box to the TV. Hooking your television directly to a digital antenna will not get you Digital signals...only analog signals.
Jun 25, 2010 | RCA TruFlat 27F520T 27" TV
HDTV Setup
it wont hurt to run both to the set, they wont interfere with each other
Nov 28, 2007 | Televison & Video
CONNECT CABLE TO MY PROJECTOR
Depending on the specific model of your Mitsubishi DLP, you can have either S video, RCA, VGA or a few other choices of INput connection.
Depending on your cable provider and hookup, you can either have a plain cable with F connector or a cable box normally with RCA connectors and a remote control.
If you have a simple cable connection that attaches direct to a TV (no remote, no box), you would need a TV Tuner to be able to receive the different channels whose output would be a composite video signal into the yellow RCA jack. You would need an RCA to RCA cable to in turn connect it to your Yellow RCA Video INput of the projector. In the absence of a tuner, an old VCR with such a feature would also serve the purpose. In some instances either units may also have an S video connection.
If you have a cable box with with remote, then there is no need for a tuner or VCR since its output would already match the projector's input.
Either way you would need a separate audio amplifier/speaker  for the sound.
Hope this be of some help/idea. Pls post back how things turns up or should you need additional information.
Good luck and kind regards.
Oct 23, 2007 | Office Equipment & Supplies
Picture problem
I have the EXACT same problem with my Sony SDM-P234 23" HD/computer monitor. I know it works (and it works great) with my DVico PCI card with my computer. It outputs in 480i, 480 p, 720p and 1080i with clarity on a simple indoor RCA HDTV antenna. I get the same quality (1080i) picture for the same three seconds as does lewy. I can also add that the digital coaxial output delivers 5.1 audio to my amp and it stays on even after the picture cuts out. Please help.....Comcast sendsa 'technician' out to service it and...well....did I say he's a 'technician'? He changed the box twice and says it must be my equipment. I guess its an act of God that it works with anything else.... I mean....its been checked out by a Comcast 'technician' after all.
Apr 14, 2007 | Arris DCT6200 DTV Receiver
Installed surround sound, no picture on tv
I could not get my TV to recognize an S-video signal from my reciever either. I ended up just bypassing the reciever and running the video straight from the cable box to the TV. It might be a better option anyways as some quality is lost if you run it through the reciever.
Mar 20, 2007 | Onkyo TX-SR602 Receiver
Mitsubishi HC100U Multimedia Projector Logo
190 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
