Question about Aiwa AV-DV75
Aiwa Home Theatre Receiver
My receiver is not coming on. There is a red ligt to indicate power but the unit is not coming on.
Any ideas?
Regards,
La Vaughn
  • 4 Answers
Same problem here...I determined that if you unplug the receiver for a few hours, it will work again for a week or so.  Someone else on this website said that it had something to do with the power relay switch:
http://www.fixya.com/support/t190750-aiwa_av_dv75_powers_off
Posted on May 31, 2008
RCA RT2770 Home Theatre Receiver
The power supply may have failed
Jun 18, 2013 | Audio Players & Recorders
My Boston Acoustic Avidea 610 home theatre receiver popped last night and lost power! it has not been able to be powered up again!
Sounds like you blew a cap or some sold state device in the power supply section of receiver. Open her up and start looking and smelling - replace bad parts and cross fingers.
Aug 27, 2017 | Boston Acoustics Avidea 610 Theater System
I have an RCA home theatre...model rt2910. I have hooked my PS3 via HDMI to the TV for the video and used an optical cable for the audio. I set the PS3 to send video via HDMI and audio via optical cable....
You should have the HDMI plugged into the Home theater unit. The theater unit then is attached to the TV using the HDMI out.
The home theater unit passes the HDMI through to the TV while playing the audio for you.
You will likely need to select the correct source on your RT2910.
Here is a link to the manual.
http://www.1800customersupport.com/productdocuments/RT2910_RCA.pdf
See the section entitled "Connecting to HDMI Components" for an illustration of what I have described above.
Feb 28, 2011 | RCA RT2910 Theater System
I have SC-PT750 Wireless system with SH-FX65T and SE-FX65, the wireless does not work and the screen flashes W1 to W2 and the SE-FX65 red light stays on
1 Turn on SE-FX65 2 While pressing [>>/>>'] ] press the numbered button [3] on the remote control until "P" lights in the home theater unit's display The indicator on SE-FX65 turns green. 3 While "P" is displayed, press [I/D SET] 4While pressing [>>/>>'} press the numbered button [3] on the remote control.
This worked for me. I moved and lost the FX65A, and Had to buy a replacement off ebay,
Used this manual http://www.specsserver.com/CACHE/FRQUJVMNXTYS.PDF but I have to give mosyzlak props, cause he gave me the idea to look for it.
Nov 28, 2010 | Panasonic Home Theater System System
Want to attach a extra subwoofer
If you have a "subwoofer-out" jack on the back of the receiver, you can put a y-cord on it and connect it to two powered subwoofers. Don't expect a big difference in the sound, however. You may even get less bass depending on where you position the sub-woofers.
Apr 29, 2009 | Audio Players & Recorders
Instalation instructions required
Uhmmm. . .okay. . .I would use nothing less than 16AWG speaker cable. Do not run the speaker cable parallel in close proximity to any AC wiring. Speaker cable rated to run through walls with usually be color coded red and black. Connected the red to the red on the speaker and red on your home theatre receiver. Do the same for the black. If speaker cable insulation is clear, look closely for subtle markings or writing on the insulation. The writing will only be on one of the two wires. Designate that as the POS or PLUS or + or RED. Connected it to the red on the speaker and the red on the back of your home theatre receiver. The other is by default the black and connect it to like colors. Repeat for all 5, or 7 speakers in your theatre. Your subwoofer probably has a seperate amplifier, so it gets it's power from it's own AC power plug. . .so plug it in. The sound coming from the Home Theatre receiver will be low-power and will carry on an RCA cable. Look for the subwoofer output on the home theatre and connect it to the input on the subwoofer. There may be a right and a left input on the woofer. . .it doesn't matter which you plug it into. . .either one will do.
Mar 09, 2009 | Audio Players & Recorders
Connecting rear Wireless Speakers on Panasonic Home Theatre Kit
Hi
Just push and hold the fast forward button on your receiver and push the button number 3 on your remote simultanously
your unit cames in pairing mode a P appear in the display
after, goes to your wireless receiver and push the reset button on the back
normally after that the unit must connect with your receiver
Dec 29, 2008 | Televison & Video
Power on but no display
Hello Coach T, Reset Instructions: 1. If pressing the power button does not turn the unit off, unplug the unit, then plug it back in. 2. Press the power button while pressing the ENTER button. This will bring the unit back to factory defaults. Please let us know if you need any additional help. Best regards, nightdiver
Aug 21, 2006 | Aiwa AV-D57 Receiver
Aiwa AV-DV75 Logo
124 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
