Question about T-Mobile Wing™ Smartphone
Wing the front and the back (the keybord) apear to be separating and is very loose. Is there any way to fix this. I never use the keyboard, so this is agravating. Doug
    New Friend:
  • 51 Answers
The only thing I can recommend yu is to bring your phone to the t-mobile and they can fix it for you. I'm sorry about your problem... goodluck
Posted on Jan 20, 2008
Keybord wire come loose
You can try popping the keyboard off, but I would recommend bringing it to a repair shop and have them fix it for you. It wont cost much.
Jun 30, 2012 | Computers & Internet
One of keybord key is lost..i ve that key..can u fix it or change the new keybord..what to do.
Usually, laptop keyboard repairs are not feasible. Best is to replace the keyboard with a new one.
Oct 23, 2010 | Acer Computers & Internet
Need to replace broken key on keybord. plastic appartus on key underside broke
Remove sticky tape securing the keyboard cable to back of the keyboard.Part of the keyboard cable is glued to the keyboard. Carefully separate the cable from the keyboard.Start peeling off the aluminum protective film Remove the protective film. After the protective film is removed it's really hard to attach it back to the keyboard because it's deformed.Most laptop keyboards have some kind of plastic separators.
These separators secured on the back of the keyboard.
Plastic pins are melted on the back of the keyboard and retain separators in place.Push all plastic pins though wholes on the keyboard.Start removing the separator.The plastic separator has been removed.
Now you'll have to remove all key caps.
Before you start removing key caps, make a picture or xerocopy of the keyboard so you know the order in which keys are attached to the keyboard.In order to remove the key cap carefully lift it up with your fingers.Remove the key cap so the hinge underneath stays connected to the keyboard.
Some big keys have a different design.
In addition to the hinge, some big keys (Back space or Space bar for example) might have an additional support bracket.Remove the key cap with the support bracket. As you see, the key hinge stays connected to the keyboard.Some laptop keyboards might have blank covers on the left and right sides from the up arrow key.Lift up and remove the blank cover.All keyboard key caps and plastic separators have been removed.Now you can start removing key hinges - key lifting mechanisms.Carefully separate the key hinge from the keyboard.
Each key hinge has two parts - external and internal pieces.
When you remove the hinge, try to keep these parts connected to each other the same way they are connected on the keyboard.If the external and internal pieces got separated, you can assemble them together.If you following this guide to repair the keyboard, I would recommend to keep all hinges in the right order.
The keyboard has two sheets laying one on the top of another.
Remove the sheet with silicone (or rubber) nipples.Remove the second sheet with traces.Both sheets have been separated from the keyboard base.The sheet with traces has two layers and all traces are running between these layers.In order to access and repair traces you'll have to separate to layers from each other.The keyboard has been disassemble.
As you see it's not easy to disassemble a laptop keyboard and even harder to put it back together.
Is it worth repairing? Probably not. These days you can find a new laptop keyboard very cheap.
Oct 17, 2010 | HP Pavilion ZD7140US Notebook
Sir my computer starts but during booting it asks for keyboard error problem and shuts down randomly n automatically sir i need a quick answer i m bored of it my computer is brand new what to do
turn computer off and unplug the keybord. then plug it back in. it sounds like the plug has wiggled loose and it is saying that you don't have a keyboard attached. this will cause a "halt on keyboard error". this is what is happening to you. if unplugging and re plugging does not help, buy a new keyboard. but is suspect that if the system is new or nearly new it has just wiggles loose is all.
Jun 27, 2010 | Computers & Internet
My mouse and keybord does not work, also the red light on the front of my computer stays on
mouse and keyboard may be plugged into the wrong ports... crossed. or ur ps2 card could be bad... easy fix ... purchase a usb mose and keyboard.
Feb 02, 2010 | ZT Group Cisnet PC Desktop
Keyboard suddenly didnt work
First make sure battery works fine .
Reattach battery .
Then uninstall wi fi keybord driver.
Then reinstall from disk which come with keybord when you purchase.
Installing driver fix keybord problem .
Let me know if you need further assistance.
Oct 28, 2009 | Belkin F8E206 Keyboard
About the Aspire 5100 notebook , Keyboard , USB port and Mouse pad not working , the problem apear when you power on , for exemple you want to go to BIOS , first power on then press an F something key on...
  1. Unplug all the device except keybord and monitor
  2. Press F2 and go to bios and you have restore the bios
  3. restart the computer, then it will be back normal.
Still have problem, just reply me
Thanks, PREM
Mar 21, 2009 | Acer Aspire 5100 Notebook
Keyboard problem - asus
it seems to me that you have the NumLk activated, deactivate it by pressing Fn + NumLk, hope this works!
Nov 01, 2008 | ASUS Eee 4G Notebook
hi sir..
go to the control panel> keybord> hardware> trouble shoot. it will be helful. please rate it sir..
Sep 03, 2008 | Gateway MT3705 Notebook
Compaq Presario v2405us Laptop keyboard help
yes u can remove keybord cheak loose connectons also FN button did u hitthat to stop keybord from working sumtime sthat doe sit hit fn button and try sum keys u can replce the keybord pretty easy get part on ebay install it yourself im open for chat thx nick helpap in saginaw michigan
Jan 07, 2008 | Compaq Keyboard
T-Mobile Wing™ Smartphone Logo
22 people viewed this question
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
