Question about Printek FormsPro 4500 Matrix Printer
Mp: bad gap home
Can't print will not do anything printer comes up with the
MP: Bad Gap Home
?? Help
Bad GAP HOME is a problem with the sensor (switch) that senses the automatically set printhead gap. Usually the wires break from flexing that run to the switch. Could be a bad switch also, or others.
You need to test the switch and wires with a meter.
Posted on Feb 20, 2008
  • macmova Feb 14, 2011
    where is the switch located? Do you have any pictures or service manuals? I am having a hard time finding any service documents related to this printer online. Please help.
    Master:
  • 619 Answers
Reinstall driver / open control panel , click printer icon , follow instrution.
Posted on Jan 03, 2008
  • 4 Answers
Bad gap home means that there is resistance on the printhead. Try cleaning the bar with alcohol and a cotton ball.
If that doesn't work, it's a power issue, and you might need a new mainboard. I know allprintersupply.com sells them.
Posted on Feb 13, 2008
How to clean Ricoh Aficio MP 2000
sounds like either drum blade has fail or drum is bad. try printing the counter report and see if it is doing this. Then photo conductor unit needs to be rebuilt or replace. open right side door and look at drum make sure you don't touch it and see if toner is on it. If so drum blade has fail. call a tech or buy new photo conductor unit. this are good for approx 60,000 copies but sometimes will go longer age also play with drum blade life. were you might have 20,000 copies but unit is 5 years old
Jan 31, 2012 | Ricoh Aficio MP 2000 Black and White...
Gaps in barcode with Zebra S4M
The gaps run in the direction of the label feed? You have a bad printhead. Bad dots on the printhead prevent it from printing your format in the areas that you see the blank lines.
There is no easy fix other than replacing the printhead. You can prevent (or actually prolong the time between failures) in the future by periodically cleaning your printhead. It's recommended that you clean the printhead after every roll of labels. The printhead is underneath the hinged assembly. Over time, ribbon or adhesive from the labels builds up and causes dots to go bad - creating the blank lines you see. Clean your new printhead with rubbing alcohol.
May 15, 2010 | Zebra S4M Thermal Label Printer
How do I have printer switch from empty paper tray 1 to the full 550 paper tray 2
Hi. You need to do tray linking. When one linked tray is empty, paper feeds from the next linked tray. The size and type settings for all trays must be set from the Paper Menu. To set the paper type or size:
1. On the home screen, touch Menu button
2. Touch Paper Menu
3. Touch Paper Size/Type.
Note: To link the multipurpose feeder, Configure MP must be set to Cassette in order for MP Feeder Size or MP
Feeder Type to appear as a menu item.
4. Touch the right or left arrows to select the same size paper from all paper sources to be linked.
5. Touch the right or left arrows to select the same type paper from all paper sources to be linked.
Note: When the Size and Type settings are the same for any trays, the trays are automatically linked.
6. Touch Submit.
Submitting changes appears.
7. Touch Home to return to the home screen.
Hope this helps.
Mar 16, 2010 | Lexmark X464DE Mono Laser MFP, 38ppm A4...
Canon Mp 510 printer does not print
mine is the same. did you find a solution to this problem?
Feb 15, 2010 | Canon PIXMA MP510 All-In-One InkJet...
Hp laserjet4 printer will not print labels or envelopes
MP LOAD,
PC LOAD, or
LC LOAD
paper size,or
envelope size
The printer received a request for a paper or
envelope size not available in the printer.
MP LOAD: Load MP Tray with the requested
media. If the size is not selected in the printer
control panel, use the [MP[Paper[Size] key to enter
the requested size, or press [Shift] + [Continue] to
draw the requested size from another source, if
available.
Note: If MP LOAD remains in the display, you may
have to clear the buffer by resetting the printer.
Press [Shift] + [Reset].
Feb 12, 2009 | HP LaserJet 4 plus Printer
I NEED HELP IN SETTING MY FUJIFLIM DIGITAL CAMERA A350 5.2 MP.TO THE 5.2 MP.BECAUSE MY PICTURES ARE COMING OUT REALLY BAD WHEN I DEVELOPED THEM.THEY SAID IT WAS BECAUSE THE CAMERA IS NOT SET TO THE...
unless your camera was set to less than 1mp your pics would print fine even at 1 or 2 mp at 4x6 size-this may not be the problem-go into your menu and you can change the resolution-if pics are still messed up tell me what they look like and i'll try to help or send me samples
Aug 24, 2008 | Fuji Cameras
Printek 4300
Sounds like a bad gap switch. You can order a fresh one at allprintersupply.com.
Jan 10, 2008 | Printek FormsPro 4500 Matrix Printer
Printek FormsPro 4500 Matrix Printer Logo
1,418 people viewed this question
Top Printek Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Marvin
Marvin
Are you a Printek Office Equipment and Supply Expert? Answer questions, earn points and help others
