Question about GoVideo Go Video DVD/VCR Combo
DVD door won't open on my Go Video DV2130
The DVD door won't open on my Go Video DV2130 machine.
  • Garnetta Jan 05, 2008
    DV3840
    My door will not open on my DV3840 GoVideo. No matter what I do the DVD will not eject, so I can not get the DVD out of the player. When I push eject it comes up on the screen that it is reading the dvd but that is it
    It just will not play nor eject.
I have a model DV1140 on my 4 year old son’s room since 2004 and I’ve seen this kind of issue before. This is mostly caused by trying to eject the DVD without pressing “stop” twice before ejecting it. But since you are already in trouble you may try this: First, let the player start to play the movie (you must let it play all the sneak previews first). Second, press “stop” twice (make sure the counter reads 0:00:00). Third, press “eject”. It should be working fine by now. If not, then you’ll probably experiencing the same issue I had today. My wife came to me complaining about the dvd player, she told me that she couldn’t get the player to eject the disc. “Women” I thought (sorry for that I didn’t mean it), but when I was trying my “magic” I heard an unusual winding noise coming out from the DVD tray. Since I couldn’t get the DVD to eject I decided to open up the player and check it for any loose or broken parts, nothing fancy anyone can do this. (If you don’t feel comfortable with this, just don’t do it and take the unit to a repair shop). Ok, now for the ones who stayed with me. Most important; first, unplug the unit from the AC outlet and disconnect it from all sources (TV, Cable, Sat, etc.). Remove a few Philips screws located at both sides and on the back panel and then remove the top lid, you should be able to see your disc by now. There should be another small black plastic “lid” on top of your DVD tray (this ensures the disc stays in place and centered), remove this lid by unscrewing another two Philips screws located on both sides of this “lid”. By now you should be able to remove your disc. After removing the disc you may try to plug the unit back to an outlet and turn it back on to look for any unusual sounds (like the one I heard) to identify any issues, (CAUTION: avoid any exposure to the laser beam). If you can’t find anything wrong yet then proceed to remove the front panel (it has a few clips all around just be careful not to break any of them). Now, check inside the DVD mechanism (a flashlight may be helpful here) when you look inside search for two small “pulleys” (mostly white)there should be a black rubber belt running around them if there is no belt around you’d just found half of the problem. If you are in luck you may find the little rubber belt (about an inch on diameter) or what is left of it inside the DVD tray. As soon as you find it you will have the other half of the problem. You see, when you press the eject button it activates a motor that spins the two “pulleys” I mentioned before with the help of the little belt you’d just found. This makes the DVD tray to move in or out of the player.
I hope this will be helpful for anyone out there with the same problem. (Remember, this work for my player (DV1140), I’m not totally sure that it’ll work for all models). As for me? Well, now I have to search for the belt p/n and were can I get two of them (one for spare). If anyone found it first you can contact me at: [email protected]
Posted on Sep 08, 2008
Yeah, I have the Go Video DVR 4100 and it recently has done the same thing. I bought it in March 2003, so this being 2008 I suppose it's time for something on it to bust. The VHS player still works though. I did the unplug and replug while holding eject button, but it still didn't open. Luckily, I have a non interest DVD in there so I' can wait. I have another DVD player I use. I'm sure one day it will accidently open due to some electronic magic elf.
Posted on Aug 30, 2008
    Genius:
  • 1,003 Answers
Unplug the dvd from wall hold the eject button down while plugging dvd player back in
Posted on Jan 15, 2008
6ya staff
SOURCE:
Why won't the doors will not open to either the video or the dvd player
Can you push the door open manually? If so you might find some alien object in there like the other day when I discovered that my son had posted an essential oils bottle into the VCR!
Mar 13, 2012 | Electronics - Others
DVD door won't open
you should get the DVD door cleaned either profesionally or just do it yourself
Feb 19, 2012 | Panasonic DMR-ES40V DVD-Video Recorder
My dvd player keeps turning off and wont play dvd or vhs
If the machine is shutting down it indicates a power supply issue on the main board, you need a service technician to isolate the problem. I have found in some cases it is due to the filter capacitor becoming open.
Jan 11, 2011 | GoVideo DV2130 DVD Player/VCR
Can you record dvd from vhs on a go video DV2130
no its just dvd player you can not record.If still need record on dvd then first input in your computer via tv/tuner card as a audio and video in put.then play vhs and record dvd from computer.
Oct 17, 2010 | GoVideo Go Video DVD/VCR Combo
Does the govideo model DV2130 have a tuner in it?
hi, my remote won't work, i change the battery, so that is not the problem, i have a go.video dv1130. what do i need to do?
Apr 27, 2009 | GoVideo DV2130 DVD Player/VCR
Display problem
hit the display button
Aug 11, 2008 | GoVideo Go Video DVD/VCR Combo
GoVideo Go Video DVD/VCR Combo Logo
310 people viewed this question
Top GoVideo Televison & Video Experts
Marvin
Marvin
Ekse
Demonic-2011
Demonic-2011
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
