Question about LaCie (300728U) 250 GB Hard Drive
Not powering up
Will not pwer up even though the power lead is on?
  • Anonymous Feb 24, 2008
    When I try to power it up the light flickers for a couple times and then goes dead.
  • 233 Answers
Purchase a USB enclosure, remove the drive and install in new enclosure, plug in and test.
hope this helps
thanks for rating
Posted on Jan 09, 2008
I've not used my TV for about 8 months n now it has no pwer. I've changed the fuse n pwer lead.
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Jan 11, 2016 | Televison & Video
Aspire 5050 just pwer off by itself
check power lead pluse battery,or it could of over heated check the fan and clean if needed.
Mar 06, 2014 | Acer Aspire 5050-3242 Notebook
NO PWER ON 2008 DODGE NITRO, CANT GET IT OPEN THOUGH AS THERE'S NO POWER AND CAN'T OPEN BONNET FOR SAME REASON, ANY SUGGESTIONS ON HOW TO GET POWER TO IT?
You may be able to run a jumper wire under the truck to the starter post and one to the frame or engine for ground.
Jan 22, 2014 | Dodge Nitro Cars & Trucks
The sound and picture goes out on my LG lcd tv. Power light stays on
if you are not a tech then take your tv to a repair man.there is a problem in your tv power supply...the pwer supply is attached to where the power cord leads to the wall outlet.good luck.kindly dont make repairs yourself.
Sep 23, 2011 | LG Televison & Video
Power supply is ok but no pwer on
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause this problem
follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
hope this helps
Jun 03, 2011 | Foxconn A6VMX Socket AM2+ AMD Motherboard...
I will power the computer up and use it for awhile and it will shut down on it's own. When I try to pwer it again the power button is blinking amber. Sometimes I can start it and use it for hours and...
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 26, 2011 | Dell Dimension 8400 power supply ** FREE...
No power comes on when I push the power button. I've checked the pwer lead to the radio and I have that. Also checked the ground and have that. Fuse is also OK. Any suggestions?
You need three wires to power on a radio
yellow 12v constant
red 12v switch (turns off/on with key)
black ground
Verify these three and the fuse on the back of the radio as well
Apr 04, 2010 | Pioneer DEH-225 CD Changer
My T5 wont power up even though the battery has a good charge and puts off a good voltage
IF you haven't done so yet, do a hard reset. Take the end off of your wand (unscrew it) there's a reset pin on the end of the cap. In the center of the back panel is a reset hole. Push gently with the reset pin.
It should pwer back up....
Jul 11, 2009 | Palm Tungsten T5 Handheld
Dimension 8200 will not turn on
Try a new power button. Also does the machine power light turn on at the front of the machine? if so check that the CPU is seated correctly as if it has come out of position then the machine doesn't boot. I would like to think power switch though.
Thanks J
Jan 17, 2008 | Dell Dimension 8200 PC Desktop
LaCie (300728U) 250 GB Hard Drive Logo
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Marvin
Marvin
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
