iLO DVDR04
How do I record the dvd+r from my camcorder?
posted by AudreyD on Jan 03, 2008
I try it but its saying invalid disc. I need your help. I have iLO dvdro4 and camcorder is JVC compact VHS camcorder.
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on May 12, 2008
Helpful (85)
ronpar
Rank:Master Master
Rating: 81%, 22 votes
are you tring to burn a disk and you tried another disk .and it still says the same thing then you can clean it but im sure that the dvd recorder is shot these ilo's are real good about that. you probley don't use it that often that's why it's lasted you this long you can replace it with a pc dvd recorder the best that iv'e used is a 16 speed dual layer. i tried a 16 speed single layer but fast foward kept frezzing up and i had to restart my ilo. so i put the 16 speed double layer in it works fine. im sorry but im sure thats whats wrong with it it took me 6 ilo's and about 200 invailed disks to find out. i would have took the sixth one back to wal-mart but it was the last one they had they had they stopped making that model the ilo 500 brand was made by some one else and not half as good as this model. besides this was the best little recorder that i had ever seen at that price and just did not have the heart to throw it out. i would buy a 16 speed dvd dual layer on-line im not sure if it needs a dual layer, it might have been just my single layer but why take the chance they don't cost any more if they do it won't be that much. you might be able to find one just like the one in it but i don't think they will be as good, and they might cost alot more. if you bye one you can pick up one in between $20 and $30 dollars. i would shop around on-line i would pick up two if i was you in case you ever need another one i don't know how long they will make these sense all you can find in wal-mart is 20 speed and i think higher. a 4,8 and 16 speed will not work there either to slow or to fast they have a 12 speed but i have neaver had one.if you decide to buy one, unplug it take the top off and take the strap and power wire out of the other dvd recorder and plug them in to the new one. i just sit the one i got on top of my ilo.to keep it from getting over heated and burn it up like the last one.i cut a little **** on the top lid in the back so the power wire and strap could slide up the back and hook into the dvd recorder. but thats up to you.to get it to fit inside you will have to take the front plat off the ilo dvd recorder and sit something like some metal or starefoam under neith the dvd recorder to sit it up high enough to come through the front hole.then you will have to strap it down to keep it from moving.but first you have to take the plate off the front of new one to slide it through the front of the ilo.that and taking the chance of over heating is why i set mine on top.but any way you just hook it up like a regular pc one. i just left the old one inside the ilo. if you dont won't to cut a **** in the lid just put your front screws in the lid and pick up on the back to leave enough room for the wies to come out wrap some black tape around were the wires are comming out so the the wires don't get cut and put something in the back corners of the case to rest the lid on so there won't be any force on the wires to cut them, and leave the back screws out .sorry this is so long but i don't know any short way to tell you this if you have any problems e-mail me at rjp6850@msn.com
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on how do I record the dvd+r from my camcorder?:
I don't want to Accept this solution
Can you Help with these DVD Players problems?
iLO DVDR04
I've recorded a dvd from a video camera and the dvd will...
iLO DVDR04
my brother gave me this player with no wires, no...
iLO DVDR04
Cannot unlock timer on above unit and it wont let me do...
iLO DVDR04
can not record to any dvd disk above 8x speed. is there...
iLO DVDR04
what is the bast blake dis to use in my ilo dvdr04. i see...
Loading problems.
Repair Service
Find DVD Player Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Home Media Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
