Question about Radio Shack Pro-96 Scanner
Display is blacked out
My pro 96 works great but the screen has blacked out.
  • Anonymous Mar 16, 2008
    backlight will light but no text will display at all. Still get sound but no display
  • ROB51788 Apr 17, 2008
    LIGHT WORKS BUT YOU CAN NOT READ THE DISPLAY.
    New Friend:
Standers420 just saved me a costly (and more imporantly hassle-filled) RS repair experience. I have a Pro96 with the exact same symptoms. In my case, all I did was take it apart per Standers420's instructions and blow a little air into the vicinity of the ribbon cable and made sure the connections were tight and it solved the problem completely - didn't even have to take the cable out and do the trimming etc. (which did scare me a bit). Also - it's important to note that on the Pro96 you must take it COMPLETELY apart - remove the back and then actually separate the board from the front of the scanner to get to the cable in question. After you have it properly disassembled you should have three parts: The back plastic cover, the main circuit board (connected to the front with a two-pin cable and multiple non-cable pin connections) and the front section which has it's own circuit board covered with a black plate. At the top of the front section is the cable in question. Also - obviously, when reassembling, it's important to make sure all the pins line up between the middle and front circuit boards. I didn't do this the first time and thought I had fried the scanner when I turned it back on. But I realligned the two sections and all was well.
Posted on Jan 03, 2010
I had the same problem with my Pro 96 display not displaying and followed thtough with Standers420's suggestion of taking the scanner apart and checking the ribbon wire from the board to the display. I put a little contact cleaner on my finger and kinda worked it into the leads on both sides of the wire, near each connection. Very carefully I might add. IT WORKED!! And it's really easy to do as well. So now for the first time in over 7 month's I have functionality back with my scanner. Because without the display, you can't actually use it to it's full capabilities. Thanks, Standers420!!
Posted on May 03, 2009
    Problem Solver:
  • 6 Answers
Take it back for repair or open it up, find the SMALL ribbon cable where it attaches the display to the board, release from connector, use SHARP scissors to cut 2mm STRAIGHT across, clean conductors, replace in connector and secure, reassemble
known issue for 96, 97, and the base units also
Posted on Feb 07, 2008
You might try adjusting the contrast -- it's in the manual.
Jerry O'Dell
Posted on Jan 09, 2008
6ya staff
SOURCE:
Radio shack pro-106 screen blank
Sad day. Try AC adapter? Fresh batteries. Do you get sound, but just no display? Did you try the 3 finger reset on the unit? You might end-up having to buy a PRO-96 to replace it if you can't get audio out of the PRO-106. Let me know.
Dec 30, 2016 | Radio Shack Radio Communications
Black screen
Have you zapped the p-ram? Hold Apple, Option, P and R keys when you hear the chime. Wait for four more chimes and release.
Try "detect displays" from display preferences. In system preferences, displays, be sure brightness control is turned up.
Feb 11, 2013 | Apple Mac Pro A1186 Desktop
Radio shack pro-96 scanner screen blinks and loss of audio
If the scanner's display locks up or does not work properly
after you connect a power source or install batteries, you
might need to initialize it.
This procedure clears all information you stored in the
scanner's memory. Initialize the scanner only when you
are sure the scanner is not working properly.
1. Turn off the scanner, then turn it on again. Multi-system
Trunking Scanner appears.
2. Press 0 while Multi-system Trunking Scanner appears.
3. Press 1.
4. Press ENT. Initializing please stand by. appears for about 5
seconds.
Do not turn off the scanner until the initalization is
complete. When the initialization is complete, M000
appears on the top line of the display. Bank 0 Ch 00
appears on the third line.
Notes
Notes
Jan 10, 2013 | Radio Shack Pro-96 Scanner
My MacBook Pro display screen is looking very strange....like a color photo negative of what it should be. White backgrounds are black, black letters are white and so on. I heard there was a problem with...
Don't worry you have put on one of the universal access settings if you go to system preferences and then universal access under display change the setting from white on black to black on white. Hope this helps
Dec 03, 2010 | Apple MacBook Pro with 17" Display
Need to reprogram hand held pro 96
Radio Shack can "CLone" your scanner with one in the store - try that first to see if it will work and let me know.
Aug 19, 2009 | Radio Shack Pro-96 Scanner
HTC Touch Pro LCD Going black and then sometimes working
is there the "calendar" and "contacts" menu buttons on the bottom of the black screen?
that's what would happen to me. i just turned off the touchFLO 3D on the today screen (by going to settings, then today screen options) and it seems to not go black anymore... even after being untouched for hours.
not sure if the same thing is happening to you, but it worked for me.
Jul 19, 2009 | HTC Touch Pro Smartphone
Bad lcd screen radio shack pro-92 hand held scanner
Do a google or yahoo search for gre america store. They may have the part you are looking for. If not they may be able to tell you where you can get the part. I know they carry parts for the pro 95 96 and 97.
Good Luck.
May 28, 2009 | Radio Shack Pro-97 Handheld Scanner
Which is the best sanner the pro96 or the pro106
I own both of these and like the 106 more. It isn't just because it is new, but it has several options that make it more "user friendly" as well as better features. Some of the high points are:
-Easier manual channel navigation
-Larger, easier to read display
-Easier scan list understanding
-Much better user interface (text menus)
-Colored LED that you can assign to different channels..such as your priority channels. This way you can see what your receiving at a glance without having to actually look at the display,
-Remote control capability using the Win500 software.
A Pro-96 is a good scanner, but the Pro-106 blows it out of the water.
Jan 26, 2009 | Radio Shack Pro-96 Scanner
PRO 96 Scanner
I had the same problem. I called Radio Shack and they said there were no channels were programed to scan. I am very new at this so I would be able to help you program but call Radio Shack at 18008437422 and hit option 2 twice. The person I got on the phone was great. Just be sure to have the numbers you want to program in front of you.
Dec 28, 2006 | Radio Shack Pro-96 Scanner
Radio Shack Pro-96 Scanner Logo
798 people viewed this question
Top Radio Shack Radio Communications Experts
Robert McClure
Jason
Perry Mellott
Perry Mellott
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
