SD tech , you said you could give me start to finish instruction on replacing the convergence chips #STK-392-110. I have located the chips where you said they would be and i can solder but having some intstruction removing the board to solder it would be most apreciated thank you in advance for any assistance aandy.4
What you will need;
Two new STK-392-110 convergence Ic’s
Solder
Liquid solder flux
Desoldering braid or wick
A good soldering Iron
Some denatured alcohol
A small toothbrush
A Philips screwdriver or screw gun to REMOVE SCREWS
A PAIR OF GLOVES
UNPLUG
TV SET.
Remove
back cover of TV set.
Remove
entire front speaker grill on set(it pulls off and may resist being
removed)
Locate
and unplug speaker wires (they are plugged into the main circuit board).
Locate
three cables with wires that come from the Front keyboard—two of them have
to be unplugged from the main board(all plugs are different sizes but note
where they go)
Remove
2 long philips silver machine bolts from the front of the set (behind the
grill).
Remove
4 more in the back of the set;two
are located at the extreme back edge of the plastic frame and hold the
chassis down; two more are located on either side and also go straight
down; note which are which and set them aside.
Using
gloves pull the entire metal box (it is called a light box) out of the
set; there are hand holds on either side—careful as the metal has sharp
edges.
Remove
the box from the set and locate the two Convergence IC chips; they are
located on identical metal heat sinks with fins and they should have the
STK-392-110 number clearly printed on them in white (they are black)
Turn
the light box over on its side and UNSOLDER ALL 18 PINS ON EACH IC. It is
a good idea to apply liquid solder flux to the pins on both chips now.I recommend using a de-soldering braid
for this—get all the pins completely de-soldered.
Inspect
the dozen or so light blue resistors in front of them; most are marked 2.2
ohms—if any are white in the middle you will need to replace them at the
same time; best way is to check all of them like checking a fuse----they
protect the set if one of the STK’s shorts in any way.
With
the STK’s completely unsoldered turn the box upright and remove the two
screws on each IC.If the chips
have never been replaced you will need to tap them loose with a putty
knife or flat bladed screwdriver.
Remove
both IC’s.
Apply
heat sink grease to the two new IC’s and install them one at a time; this
part can take some time and it is important the pins on the new IC’s are
perfectly straight---once you get them in, Hand tighten both the screws on
each IC---do not use a screw gun—you can strip the screw holes out.Clean the bottom of the circuit board
where the chips were soldered with some denatured alcohol and apply liquid
solder flux to all the pins.
Presuming
you have already found/replaced any bad resistors turn the box back over
and solder carefully both of the two new IC’s in, --do not short any of
the pins to each other when you do this and when you are done it is a good
idea to take a close look at both to make sure all pins are soldered and
not touching each other with soldering you have just done. I suggest you
do clean the pins on the bottom of the circuit board again with denatured alcohol.
Slide
entire light box back into the cabinet.
Reconnect
the plugs you removed when you removed the box. At this point take a lens
cloth or a paper towel with glass cleaner sprayed on it and clean the
three large black lens-if they are dusty the picture will be darker and not
as clear as is should.
Position
the box so it is all the way in place and none of the wires or plugs are
pinched.
I
usually at this point turn the set on before I replace the Six bolts that
hold it in—2 from the front and the four in back----this way if you have a
problem you can remove the box faster.
If the
set comes on and now has normal Convergence go into the customer menu and
adjust the convergence in the multi-point mode----CAREFUL! THE FIRST
OPTIONthis set usually offers is a
green cross in the middle of the screen—do not adjust Green!
Once
you have the Red and Blue in the center adjusted find the second
convergence mode---it will give you 8 or nine points on the screen with
instructions on how to change from blue to red---use the original remote
with the thumb wheel or cursor buttons to adjust.
NOTE:
SOME of these sets need to have the Convergence adjusted in first:
full/4:3 and second in the other two zoom/wide zoom and third on the HD
input with a HD signal coming in.There is also an option at this point to go into the Technical menu
and fine adjust the convergence all over the screen—if you need this I can
give you instructions based on the model you have—most of the time
adjusting the set in the customer mode will produce a good result.
I know
all this may seem complicated to you, but this repair should take about an
hour or so and just take your time when you get to adjusting the set.
If all
looks good turn the set off and Unplug it; install all 6 of the chassis
bolts back; replace the back cover and the Speaker grill and plug the set
back in.
You
may find it useful to go over the convergence Adjust again—to get all the
points as good as you can.There is
a hidden Tech menu that will allow a finer adjustment of the entire
screen----it is somewhat difficult to access and there are a lot of
buttons on the remote that then do different things.
Most
of the time adjusting in the customer menu will give you a very acceptable
picture.
Nov 02, 2009
- INSTRUCTIONS POSTED HERE--LET ME KNOW IF YOU NEED HELP OR HAVE QUESTIONS.
I am not SD Tech, but I can help you with this problem.
The chips are located on the signal board which you have already located. To remove that board you need to remove all the screws from the board, just look around at the entire surface, there should be one in the middle and the rest are along the edges. You will need a short Philips for the front ones.
After you have removed the screws you will have to remove the back AV cover, just remove all the black screws from the back of the cover and unplug the tuner switch. The tuner switch just unplugs from the board and the tuner. If you have dual tuners just unplug the second one as well.
Then remove all of the electrical connectors off of the signal board, don’t worry too much as they are all different sizes and most of the time they have letters that correspond to the plug on the board. There are three small 4 wire plugs in the middle of the board towards the front of the set that are all the same. If you have different colored sharpie markers just mark one a different color as you unplug them. These are important because they control the convergence to each tube. If you don’t have different colored sharpies then just mark them with a black sharpie and mark them will lines, IE; one line on the first one and so one.
When you remove the old IC's, please be sure to remove all of the old heat sink compound, as it can act as an insulation for the new IC's and cause them to overheat. I usually clean the heat sinks with alcohol and a small rag. Apply the new heat sink compound with a toothpick or some similar device and spread it evenly across the chip before you install them into the board. Once they are installed then you can secure them with the screws and don’t worry about the excess compound the squeezes out of the back of the chip, it will be OK. Once you have the new chips installed check on the resistors and replace any that are charred or open, you can test them with a DVM on the OHM setting for the resistance value marked on the resistor. Check for two resistors on the front of the board toward the middle these are the power supply resistors for the convergence IC’s. If they are open or charred, replace them as well. At this point you should be able to reinstall the board, hook up the wired connections and then fire up the set before you put the back on. This will tell you if the set is going to work or not. If the set works, just finish putting the back on and then set up the convergence. It will need some adjusting because the new IC’s will be a little different. If the set does not power up, let me know and I will try to help you with some further trouble shooting tips. I hope this information allows you to resolve this issue. If you need further assistance please comment to this post and I will try to help you further. Thanks for using FixYa asnowman
my bottom part of tv to the left side became a little wavy and it's showing double and you can see...
(More)
my bottom part of tv to the left side became a little wavy and it's showing double and you can see also letteing in red color.
i have a pt-52LCX16,it shuts off and then back on by itself,what is problem ,green light flashes...
(More)
i have a pt-52LCX16,it shuts off and then back on by itself,what is problem ,green light flashes just like when u first turn it on, no other problem
