Question about LG WM-3677HW Front Load Washer / Dryer
Wm-36777hw all in one errors
I have had this machine for about 2 years and all of a sudden, the tub won't spin. it makes the noise like it wants to but after a minute, it beeps and the "LE" error code appears. i have tried unplugging it for an hour and it doesn't change. is there anything else i can do? is there a way to reset the machine? i don't see one in the manual or maybe i'm not reading it thoroughly enough.
  • saranorm Jan 03, 2008
    it had been unplugged for the better part of 3 days, only trying intermittently to try to get it to work. where do i look for loose wires? i use less detergent than recommended because i know front loaders are more effective. the tub will free spin if you turn it with your hand but the machine wont spin itself. what can i do to repair the issue?
    President:
  • 1,294 Answers
Press "end of cycle". Plug off the wall. Code can be an indication of several issues. The most common cause is over-sudsing in the machine. Overloading the wash with too much laundry may also cause the LE error code. Lastly, a breakdown in the signal between the microprocessor and the motor may cause that error code. This can occur if there is a loose wire, see that all wires are tightened..........
And rate me pl.............if helped.
Posted on Jan 03, 2008
Model WM-14316FD. Why is drum out of alignment and making a knocking noise when it washes and spins?
You need to open the machine and check that the bolt in the center of the tub/motor is tight, tighten if loose.
Other possible cause is the tub bearings.
Feb 15, 2016 | LG Washing Machines
Kenmore elite quiet pak 2
No it is very expensive to repair. You have to buy the whole rear portion of the outer drum if it is the bearings. Or a tub spider which holds the inner tub to the spindle that spins it. it is a very labor intensive repair. you would also need the outer tub seal/gasket for reassembly. If you are a skilled mechanic you may be able to repair it cheaper than a new one, but be prepared to spent the better part of you weekend working on it.
Nov 16, 2013 | Washing Machines
I have an LG WM-0532HW Front Load Washer. upon trying to fix a diffierent problem, something popped. I couldn't find anything broken. However, the inside metallic tub is not longer stable. During the...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Jun 26, 2011 | LG WM-0532HW Front Load Washer
It shakes rapidly while on the spin cycle
Check out this tip I wrote about the noise and vibration that front load washers can make..
heatman101
Apr 16, 2011 | LG WM-2077C Front Load Washer
Ok my LG front loading washer agitates but when it comes to spin it makes a very irritating high grinding noise and does not spin. There is no error displayed but that may be because I stop it before it...
I have a similar problem. The washer was showing error code UE, but would tumble when empty in test mode, but would not spin and made a grinding noise. The bolt that attaches the rotor to the motor was loose and the rotor was spinning on the spindle that rotates the drum. I tightened the bolt, and it spins when empty, but still gives a UE error code when full. Remove the rear cover and check the tightness of the center bolt.
Dec 16, 2010 | LG WM-2277HW Front Load Washer
Front load duet whirlpool makes loud roar when it spins - no error code. Machine is only about 1 year old and just started making this noise recently
heatman101
Oct 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My LG Wm 2432HW is making a lot of noise when it goes into the spin cycle. Is there an adjustment for the direct drive gears? The machine is level and it occurs with any load of laundry.
check your the inside tub for play if the tub moves up and down or side to side loosely your bearings are possibly going out. mine did that and it wasn't long before it ground a hole in the outer tub causing a massive leak.
Nov 05, 2009 | LG WM2432H Front Load Washing Machine
Tub makes loud thumping noise when spinning
Good morning! It's common to hear a loud thumping noise during spinning because the load (clothes) are not properly place in the tub. Please try to put the load in order & compress it down. best regards.
May 02, 2009 | Washing Machines
Roaring noise during spin cycle
The roaring noise is from the drum bearing and it will only get worse with time until it fails completely. You will need to replace the rear tub assembly which is about $300 for the part. The rear tub assembly part number is 285984. It will take about 2 hours in labor.
Make sure you are using HE (high efficiency) detergent and only about 2 tablespoons per load.
Mar 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
VERY LOUD GRINDING NOISE LG WM-2277HW Front Load Washer
Get a new washer. Perhaps another brand.
The fix for me was to get a new washer. Had same issue with loud spin cycle. Tried researching while wife was continuing use of washer. Then the LE message appeared.
Took back apart and found that water had leaked and caused a boat load of damage. Bearings shot, seal leaks, drum leaks, Stator damaged. Same issue as 'jammy64' stated.
Cost to repair wasn't worth it. Going to get an
Electrolux model.
May 19, 2008 | LG WM-2277HW Front Load Washer
LG WM-3677HW Front Load Washer / Dryer Logo
119 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
