Question about Archos 605 Digital Media Player
Internet access Well finally i managed to get my plug ins on my computer and ready to load but when i connect the archos to the pc notheing seems to happen ie no recognition of the added hardware on the computer ; any ideas what i do from here ; had the thing two weeks and not getting very far with it
  • 3 more comments
  • finochops Jan 03, 2008
    firmware is updated as far as i know _ problem is in finding hardware on my new pc _ shows as hardware found but how do i then find archos on the pc ; is it via control panel?
    also when i attach usb i am asked to enable usb and when picking yes it then asks for a parental coded number which i havent set up and so dont know ; ps am of voting age
    pc is brand spanking new acer media centre
    god help when i want to download video from pc!!
  • finochops Jan 04, 2008
    which button ? the on _ off button
    cant find any code numbers on my emails from archos confirming plug ins
  • finochops Jan 07, 2008
    sent an email to archos ; they replied back with a link to a website which didnt work ; back to square 1 ; plugs are on my 2 pcs ; if i switch on archos and attache usb nothing happens at all
  • finochops Jan 09, 2008
    nothing happens - i will try usb at back of computer now in case that helps
    President:
  • 1,944 Answers
  • 6 more comments
  • Damen Wong
    Damen Wong Jan 03, 2008
  • Damen Wong
    Did you install the plug in on your unit?
    How to install a plug-in.
    1. Save the plug-in.
    Generation 4:
    Save the attached zipped file (type .zip) to a convenient place on your PC, such as the desktop, and un-zip it. This will give you a folder with the plug-in inside of it. Keep this folder and plug-in just in case you need to re-install it at a later date. If you bought more than one plug-in, you will have to install one after the other, not both at the same time.
    Generation 5:
    Save plug-in file (type .aos) to a convenient place on your PC, such as the desktop.
    2. Connect your Archos device to your computer.
    Using the ARCHOS USB cable, plug your Archos device into your computer and connect in "PC Hard Drive Mode". Double click to open the Archos 'hard drive' (your Computer sees the Archos device as if it were an external hard drive).
    3. Copy the plug-in onto the Archos.
    Copy and paste the plug-in (type .aas) onto the Archos device, but not into any specific folder (this is called the root level).
    4. Activate the plug-in.
    Safely disconnect your ARCHOS device from the computer by using the green disconnect arrow icon in the system tray and then unplug the USB cable. Your ARCHOS device will automatically start the update. You will be prompted to re-plug in the USB cable in order to power the device during the update process. The update will take about one minute. Do not unplug the USB cable powering the device during the update as this could potentially render your device unusable.
  • Damen Wong
    Here are lots of How to do Guides guides (look under Generation 5)
    http://www.archos.com/support/support_te...
  • Damen Wong
    Damen Wong Jan 04, 2008
    Did you try master reseting the unit?
    resetting your AR CHOS
    In the event that your ARCHOS freezes or does not respond anymore, try to reset
    it: press the button for 15 seconds (the ARCHOS will shut down completely)
    and turn it on as usual.
    If this does not work, you can also press the “master reset” button.
    You can use the end of a paper clip to press the button in the hole.
  • Damen Wong
    No, there is a button on the back corner.
  • Damen Wong
    Did u manage to reset the unit?
  • Damen Wong
    Damen Wong Jan 07, 2008
    When you attach it absolutely nothing happens? No pop ups or messages of any sort?
  • Damen Wong
    Damen Wong Jan 09, 2008
    Ok, let mw know what happens.
    Guru:
  • 1,894 Answers
Please tell problem more in detail
Posted on Jan 03, 2008
  • 4 more comments
  • dewan nafees ahmed Jan 03, 2008
    did you connect the player when it was powerd ON? only then it will get detected
    note secon point in this link. read the note there. tell me if you have done everything as it is said there.
    here is the link again
    reply me what you do
    first update the driver software.
    then see if it works. then update the firmware as our fellow expert said.
    now even after this it is not detecting means.
    after inserting it in POWER ON mode restart the system. it must show as a drive on your system.
    even if it is not working i think it must be some problem with your PC.
  • dewan nafees ahmed Jan 04, 2008
    Once you buy the plug-in, you get a code that you type in to the 605 to unlock it.
    i think of two possiblities of getting it as a drive in your system.
    1>>find the code for parental lock from the plugin provider and unlock it.
    2>>eve after unlocking it there is no detection of it as a drive means. connect it and restart the system
  • dewan nafees ahmed Jan 05, 2008
    you must have got the code from the mail in which you got your plugins
    if not mail him and ask for it.
    you need to get the code along with the plugins
  • dewan nafees ahmed Jan 08, 2008
    ooops this is really very bad. there is something very bad with the unit. if the device is connected at least do you get as "some hard ware detected?"
    if you are not getting even that message then there is some problem with your device.
    yes now the problem will go like this. the device is getting ready for connection with the PC. but that parental code kind of stuff is not allowing it to connect with the PC. its correct. only after you clear that stage you will get the device connected in your PC.
    and so you first try to unlock it. and as far as i read every where over net i read that they will send the code with the mail itself.
    that will be the last option i think.
    thank you.
Hello i have a problem with Archos 5 Internet tablet... our isp give me a ip adress And Vpn connection & i can connect with laptop but in archos i connect to wireless access point but i can't...
Hi, Unfortunatly there is no solution with your current set up, you will need a medium grade router like a draytek 2820, that can establish the vpn from itself rather than from the computer, this way the vpn is established from the router, and when your archos connects to the router it will also have access to the vpn.
Jun 02, 2011 | Computers & Internet
CProblems onnecting Archos 700 after connecting 605 to PC
It is very possible the drivers conflict. You should try uninstalling everything to do with the one you don't want. Then install the drivers/software for the 700. Also what software are you using and what version?
Thanks,
Lee
Sep 21, 2008 | Archos AV700 Digital Media Player
My archos vision 1 is not recognised by computer
Hi, archos vision 1 player not recognized by the computer
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see archos vision 1 player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the archos vision 1 player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: archos vision 1 Players can connect to your computer in MSC or MTP mode. Exceptions are archos vision 1 Connect and archos vision 1 Express which only use MTP mode. MTP mode is the recommended and default method for archos vision 1 Players when used with Windows OS.
The archos vision 1 player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Have a nice day....
Feb 19, 2011 | Audio Players & Recorders
My archos 605 wifi is stuck in recovery
I fixed my son's 605 4 GB had Recovery code (104) on it These are the steps i followed
* Use the computer for this process that you always used for this archos
* Download the firware Upgrade 2.1
* Plug the Archos to Pc
* When the white screen comes up do format
* Wait until all done then put the firmware in to the root sector of the Archos
* Safely remove the usb for Archos from your pc first and then unplug the cable.
* Do not pick any option on the Archos screen
* Just turn it off from the power button by holding it until it turns off
* Wait about 5 minutes and plug in back to pc
* it will come up with white screen again but this time it will start Update you will see the progress bar moving wait until it is all done and it will shut off. Turn it back on Your archos will be back to normal.
When you go to download from Archos site it will explain how to download depending upon how your device pops up on your Pc.
Hope this helps
Jul 29, 2009 | Archos 605 WiFi Digital Media Player
The archos 5 won't connect to the computer with the usb.
Ijust bought a archos 5 250gb , conected via usb and drag some music from pc to archos . A few hours late the archos stopped, the pc don´t recognize the archos .
I pressed the on/off and vol together and formated the aarchos .
now had been disaster , the display just appeared the ARCOS Entertainement you way . the pc don´t regognizer the ARCHOS, NOTHING APPEARED .
Mar 20, 2009 | Archos Internet Media Tablet MP3 Player
Archos 605i
First off, I would recommend at least to get you going, that you NOT use the Archos to buy your plug-ins. Instead go to a desktop or laptop computer and buy your plug-ins using it. You will get the files you need by email. Once you copy them to the root of your Archos, the upgrade is painless. You likely will need the latest firmware before you upgrade so make sure you get that first.
I bought 4 Plug-ins for my Archos 605 WiFi TV+(Cinema+Podcast+Web)plugins for about $38.00 US on eBay. The deal was quick and cost much less than I would have paid to buy them directly from Archos. The seller I bought from claims to be an authorized reseller. I believe this is true because when I went to Archos, I found my player already registered. You may also find that you can get a similar bulk price for plug-ins for at the Archos Forum.
Dec 31, 2008 | Archos 605 WiFi Digital Media Player
ARCHOS 605 30MB SLOW INTERNET SPEED and OPERA BROWSER CRASHING: Speed tests from Speakeasy.net show download speed less than 300Kb/s and up load speed is 127Kb/s, while an adjacent wireless laptop...
How do I get internet away from my house on my archos 605 wifi, I can get it on my BTHUB in the house, is there a list of HUB I can conect to. when I try to conect a list comes up but they are all locked
Nov 11, 2008 | Audio Players & Recorders
Usb cable for archos 404
Check device manager and verify that it is showing up in there. Also, have you checked My Computer?
Mar 25, 2008 | Archos 404 Digital Media Player
Archos 605 30 gb
Yes you can download music from the net
No you can't use it as a word processor (not yet anyway)
Widgets are not yet available - they are due any time now
Check you have the output from the cable box to the input on the docking station and the output from the docking station to the input on the TV. Double check all your connections. If in doubt, rip them all out and start over. Once connected you will have to set the TV to one of the Aux channels to see the content and ensure you hit the TV button on the Archos to push the output to the TV.
Oct 03, 2007 | Archos 605 Digital Media Player
Archos 605 Digital Media Player Logo
64 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
