Question about Proscan PSVR64 VHS VCR
ProScan Model # PSVR61
VCR has "error Message 01" Please help with identifying the problem and a possible solution.
Internal memory formatting error to sony DSC-T2 camera error c:13:01
In DSCT2 Camera, the C:13:01 error message indicates a Self diagnostic message. This message can be clearly identified by the help of a Sony Authorized service technician. Each of these codes indicates the symptoms and resolutions of the Camera. In C:13:01, the issue is with the Internal Memory or with the Memory Stick.
The Symptoms are:
1. Format error with the Internal Memory which can be corrected by formatting the Internal Memory.
2. Unformatted "Memory Stick Duo" which can be resolved by formatting the MS in the Camera.
3. "Memory Stick Duo" is broken or not compatible which can be resolved by inserting a new compatible MS.
4. There may be an issue with the Hardware part also, which can be resolved by the technicians.
Try turning the power off and on again, or taking out and inserting the "Memory Stick Duo" several times may also help in resolving the issue.
Thanks.
Oct 21, 2010 | Sony Cyber-Shot DSC-T5 Digital Camera
Trying to hookup vhs analog player to hd proscan
your toshiba player should have output composite video and audio which are color coded Yellow for video, red and white for audio same goes for proscan hdtv. connect between the two keeping in mind color of cables. If the toshiba player is really old you can connect the RF cable output to antenna input to the proscan tv and watch taped programs from the player on channel 3 of the proscan tv. If then you want to keep the hookup and still watch HDTV connect the antenna to the toshiba vcr and when you shut off the vcr you can now watch the hdtv channels as usual because now you are bypassing the antenna to the Proscan tv. Hope this Helps..
Dec 29, 2009 | Proscan 32LB30QD 32 in. LCD TV
Error message F-01 & flashing lights etc I have a Hotpoint aquarius, WMF740. Suddenly returning to the kitchen I noticed an error message - the machine was switched off - which says F-01 and flashes...
Error code F01 indicates a short circuit motor triac.
You need to check connections on the motor, the motor plug and the module.
Having said that, you really should ring the manufacture, as the washer is still obviously under guarantee, and should be fixed at no cost to you.
The point to bear in mind is that if you do anything to it yourself, then in theory, you could invalidate the guarantee.
So, unless it is anything obvious, then I would advise you ring the manufacturer.
Hope this is of assistance to you.
Please rate my solution.
Thankyou.
Dec 21, 2009 | Hotpoint Washing Machines
Problem with my vcr
with your remote just hold on the power button! and you will get a cheery hello!!
Jun 09, 2008 | Proscan PSVR65 VHS VCR
Panasonic DVD/VCR message U61
Dear stds ~ My DVD Recorder Keeps Opening & Closeing The Tray A Gives An Error Message Saying ~ Repair Has Failed ~
DVD Recorder ~ DMR ES46V Panasonic ~
Error Message ~ U61 !
If Possible To Resolve ~
Please Do !
Before I Buy A New One !
Please Respond ASAP To ~ glvw@nyc.rr.com
Thanks !
May 22, 2008 | Panasonic DMR-ES46VS DVD Recorder/VCR
Panasonic DP-190 Error Message
E01-31 is a scanning lamp error"does not turn on. possible solutions. scanning lamp cable defective.
spc board or sc board is defective
Jan 03, 2008 | Panasonic DP190 All-In-One Laser Printer
Proscan vcr
you must have the vcr on child lock.should be somewhere on your remote to switch off or go through menu
Dec 14, 2007 | Proscan PSVR72 VHS VCR
Lcd 32" proscan need code for universal remote
Wow it took me a couple hours but hey i found the code ever1 needs and its a 5 digit code for comcast remotes with the red ok button the codes r 10090 or 10030 hope ive helped u out good luck
Oct 19, 2007 | Proscan 32LA30Q Television
Proscan vcr psvr70
Sounds like it's wired up wrong...try this:
take cable line to VCR in, VCR out to cable/receiver box(if you have one) then box to TV...it sounds like the vcr is getting the channels from the box and not the vcr...you will need to have the vcr scan the channels (round in the settings menu) You will also be able to watch and record 2 different things.
Oct 18, 2007 | Proscan PSVR70 VCR
Used a wet VHS cleaner and now my VCR doesn't work right. Help!!
The VHS cleaning cassette possibly deposited fiber in the heads in the drum. You may need to open the cabin and examine the heads and the mechanism for foreign matterial.
Feb 02, 2007 | Proscan PSVR72 VHS VCR
Televison & Video Logo
122 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
