Question about LG Prada KE850 Cellular Phone
Phone turns off when called if personal ring tone set
I tried calling my prada from my other phone.  I have set the one and only sound file that I could save to the phone as a ring tone. When I ring it, the phone turns off. The other thing that happens is that if I have a jpeg assigned to a contact, whether I also set my own sound or not, it defaults back to the phone's original ring tone when called by that contact.
This is a weird one - the phone memory only lets me save one music file to it before saying it's memory is full and as files need to be saved to phone to enable assigning to contacts, it proves very restricting.  If you want to use more than one tune in your contacts list you are done for due to the small memory the phone has.  Why does this phone give you seemingly, such versatility yet in reality it renders it's own capabilities impossible to implement!  I am so frustrated with this!
Turn the shit back to LG.... They are succers...
Posted on Jan 03, 2008
Somehow I have a bell icon on the screen at the bottom left with the words OFF beside it and now the phone does not ring only the ring on the fax/printer. Thanks Margaret
Hi margaret, is there a ringer switch either on the phone handset, or is there an option in the the fax settings to go directly to print. The issue sounds fairly straight forward, somewhere the phone ringer, or the settings for the phone to ring has been inadvetently switched off. Some investigation shoud bear fruit
Jun 08, 2015 | Bell Lands Phones
Tip
Audio files/MP3 and ring tones
Discovery: You are able to download wave files (and other audio file types) to your phone and even be given the feature, 'set as ring tone' -DONT.
You will find that your phone malfunctions if you set anything other than an MP3 from your phone's MP3 folder, as a ring tone.
It's the fault of the phone's firmware that leads you to believe you can select a ring tone from an audio file that is stored outside of the MP3 folder.
 It is also evident, with the limited memory the phone itself has to store MP3s, that you will NOT be able to personalize ring tones for every contact in your phone book!  Again, this is not explained in the manual properly and has led to much confusion surrounding MP3 functionality on the Prada LG.
I hope this helps.
on Jan 04, 2008 | LG Prada KE850 Cellular Phone
My phone is not ringing when I get incoming calls, beeping when I get txts, and it won't go on loud speaker. The volume is high. Its set to normal profile, with ringing volume high. Please advise.
Some how your phone was reset or had the tone turned off. Just follow the below guide and your audio should come back on. I would do a soft reset (turn off the handset, remove the battery then reinsert) before performing the instructions.
Tone settings
To select a ringing tone for voice calls, select Tones >
Ringing tone.
To select a ringing tone for video calls, select Tones > Video
call tone.
To set the ringing type, select Tones > Ringing type. You
can also set the device to sound a ringing tone that is a
combination of the spoken name of the caller and the
selected ringing tone, when someone from your contacts list
calls you. Select Tones > Say caller's name.
To set the volume level of the ringing tone, select Tones >
Ringing volume.
To set the various alert tones, select Tones > Message alert
tone, E-mail alert tone, Calendar alarm tone, or Clock
alarm tone.
To set the device to vibrate when you receive a call, select
Tones > Vibrating alert.
To set the volume level of the device keypad tones, select
Tones > Keypad tones.
I have included a link to download your user manual if needed, it comes as a PDF file so you need to have adobe PDF down loader
http://nds1.nokia.com/phones/files/guides/Nokia_E63-1_UG_en.pdf
Apr 23, 2011 | Nokia E63 Cell Phone
Panasonic kx-tga101s -- problem regarding making conference call - this is very much helpfull. But i have weird problem, i did call 1 person, and then i asked the person to hold and i made the other call....
Some Panasonic cordless phones come with up to five handsets each will need to be properly adjusted. You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU button on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced with panasonic phones.
Jan 26, 2011 | Panasonic KX-TG2740 Cordless Phone
While coming calls the ring tone is not properly working...the is raising and slowing down.please help me
Go to the settings option and then select your profile and then personalize,then in the ringtone option it would be set as descending,set it as ringing and your problem is gone..:)
Dec 11, 2010 | Nokia E63 Cell Phone
When i receive a text message my nokia E72 doesnt ring, what could be the problem?
Does the phone ring when you receive an incoming call? If so, press Menu go to Control Panel (or might be the profile is shown in the menu) after control panel, Profile then Options and then Personalize, then, scroll down and again select Message Alert Tone, set the Tone for the message. Also make sure that the volume is turned up. Save the settings and try again. If this doesn't help and you don't hear any ring tone during an incoming call, let me know after checking the sound settings.
Good luck.
Thanks for using FixYa.
Sep 03, 2010 | Nokia N72 Cellular Phone
Trying to have caller specific ring tones on mobile phone
in the groups in the call settings or under the call settings it can be done
Sep 13, 2009 | Cell Phones
Nokia e50 wont notify me when i recieve a new text message
Hello there! thanks for using Fixya.com!
Try the following instructions, to personalize your Nokia E50!
Profiles
Warning: In the offline profile you cannot make or receive any calls, or use other features that require network
coverage. Calls still may be possible to the official emergency number programmed into your device. To make calls,
you must first activate the phone function by changing profiles. If the device has been locked, enter the lock code.
Select Menu > Tools > Profiles.
You can adjust and customize the ringing tones, alert tones, and other device tones for different events, environments, or caller
groups.
To customize a profile, scroll to the desired profile in the list, and select Options > Personalise.
Define the following settings:
Ringing tone — Select a ringing tone from the list, or select Tone downloads to open a bookmark folder containing a list of
bookmarks for downloading tones using the browser. To listen to the selected tone, select Play. If you have two alternate
phone lines in use, you can specify a ringing tone for each line.
Say caller's name — Activate the text-to-speech ringing tone feature. When someone from your contacts list calls you, the
device sounds a ringing tone that is a combination of the spoken name of the contact and the selected ringing tone.
Ringing type — Select how you want the ringing tone to alert.
Ringing volume — Select the volume level of the ringing tone.
Message alert tone — Select a tone for received text messages.
Or you may still go to this website for more info! http://nds1.nokia.com/phones/files/guides/nokia_E50
Feb 15, 2009 | Nokia E50
LG Prada Loud Speaker & Exculating Ring Tone
press the lock key on the side during a call to activate the speaker phone option and then press the required touch button on the screen.
Piyush
Jun 10, 2008 | LG Prada KE850 Cellular Phone
Unable to make or recieve calls
have a look your security setting under settings menu and go into the call barring section to click cancel all. try it and hope it can help!
Sep 11, 2007 | LG Prada KE850 Cellular Phone
LG Prada KE850 Cellular Phone Logo
47 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
